Problem with connecting to IOT cloud MKR WIFI 1010
Hi
I have a problem with connceting MKR WIFI 1010 to IOT cloud ( NINA WIFI firmware 1.4.1)
I can add a device but then when I am trying to create a Thing I can not provide network credentials - button "network" is greyed and not responsive.
Also after a while it seems the device is not connected. then I need to delete it and add it again and then it becomes ready to connect but still I can not provide network credentials.( see attached print screen.)
I can not firgure out what is the problem
Thanks for any tips with that
Hi Yarkeen,
I'm facing the exact same issue, I'm trying a solution since 7 day. If you find a working solution. Please share it with me too. I'll be very thankful. If I find a solution,
I'll update here...
Thanks.
I am also having this issue. >:(
I'll post if I can resolve it on my own.
OK... This seems a bit ridiculous, but I created a variable and the configure button became functional. I hope this works for others.
I have a project with an MKR 1010 with a DHT11 connected. I cannot get the data to appear on the Dashboard. When in the cloud setup it says online. When in the cloud serial monitor I get the readings from the board, however can't seem to get the data to appear on the dashboard. Where can I find an example code for other sensors connected to the Arduino IoT Cloud? There is very little documentation. The step by step is really lacking in step by step.
Hi, you need to create a variable to get the Network Configure option.
