Links:
Arduino to sql: GitHub - mustafakemalgilor/arduino-mssql: A TDS 7.0 implementation for Arduino, allowing connection to Microsoft SQL Server and running queries. (using UIPEthernet or Ethernet)
UIPethernet: GitHub - UIPEthernet/UIPEthernet: UIPEthernet library for Arduino IDE,Eclipse with arduino plugin and MBED/SMeshStudio (AVR,STM32F,ESP8266,Intel ARC32, Nordic nRF51, Teensy boards,Realtek Ameba(RTL8195A,RTL8710)), ENC28j60 network chip. Compatible with Wiznet W5100 Ethernet library API.
//Included by myself!!!
#include <Dhcp.h>
#include <Dns.h>
#include <ethernet_comp.h>
#include <UIPClient.h>
#include <UIPEthernet.h>
#include <UIPServer.h>
#include <UIPUdp.h>
#include <Ethernet.h>
#include "sqlard.h"
uint8_t Ethernet_MacAddr[6] = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x31 }; /* MAC ADRESİ */
static byte Static_IPAddr[] = { 172, 16, 1, 2 };
static byte Gateway_IPAddr[] = { 172, 16, 1, 1 };
static byte Subnet_Mask[] = { 255, 255, 0, 0 };
EthernetClient client;
SQLard MSSQL(Gateway_IPAddr, 1433, &client);
while (!Serial);
Ethernet.begin(Ethernet_MacAddr, Static_IPAddr, Gateway_IPAddr, Gateway_IPAddr, Subnet_Mask);
if (MSSQL.connect())
MSSQL.setCredentials(L"arduino", L"ard_login", L"ard_password", L"hostx");
MSSQL.login();
int loop_count = 0;
delay(5000);
long affected_rows = MSSQL.executeNonQuery(L"INSERT INTO [dbo].[test]([data]) VALUES('deger1234') ");
long yeni = MSSQL.executeNonQuery(L"DROP TABLE [dbo].[test23]");
Serial.print(affected_rows);
Serial.println(" row(s) affected.");
if (!client) {
Serial.println("disconnecting.");
client.stop();
if (++loop_count == 10)
MSSQL.executeNonQuery(L"DELETE FROM [dbo].[test]");
loop_count = 0;
Errors (some of them):
In file included from sqlard_test.ino:5:0:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:25:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “Client.h”
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:26:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “utility/mempool.h”
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:29:4: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “utility/uip.h”
In file included from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPEthernet.h:34:0,
from sqlard_test.ino:6:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:23:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “Server.h”
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:24:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
#import “UIPClient.h”
In file included from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPUdp.h:23:0,
from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/Dhcp.h:7,
from sqlard_test.ino:2:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:5:24: error: redefinition of ‘class UIPClient’
#define EthernetClient UIPClient
C:\Program Files (x86)\Arduino\libraries\Ethernet\src/EthernetClient.h:8:7: note: in expansion of macro ‘EthernetClient’
class EthernetClient : public Client {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:63:7: error: previous definition of ‘class UIPClient’
class UIPClient : public Client {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:6:24: error: redefinition of ‘class UIPServer’
#define EthernetServer UIPServer
C:\Program Files (x86)\Arduino\libraries\Ethernet\src/EthernetServer.h:8:7: note: in expansion of macro ‘EthernetServer’
class EthernetServer :
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:26:7: error: previous definition of ‘class UIPServer’
class UIPServer : public Server {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:4:18: error: conflicting declaration ‘EthernetClass UIPEthernet’
#define Ethernet UIPEthernet
Error de compilación
