Code:
#include <Tlc5940.h>
int i,j=1;
Tlc.init() ;
int i,j;
Tlc.set(i=random(0,47),j=constrain(random(0,30)-3,0,100));
Serial.print(i);Serial.print(':');Serial.println(j);
Tlc.update();
delay(40);
Serial monitor output:
28:5
9:0
10:16
31:-1
6:16
34:16
4:0
39:22
38:4
23:16
16:-1
27:2
11:0
31:20
Why the "-1" ?? (It makes the LED full ON which I do not want)
Loosing my mind here... it gets worse. Changing the important line to
Tlc.set(i=random(0,47),j=constrain(random(0,30)*20,0,100));
I get output
23:100
44:100
16:100
8:80
3:320
43:100
26:100
int i,j=1;
Tlc.init() ;
int i,j,t;
i=random(0,47);
t=random(0,30)-3;
j=constrain(t,0,100);
Tlc.set(i,j);
Tlc.update();
delay(40);
...produces?
FYI, the two global variables are excised by the linker.
westfw
5
#define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
A good example of why C macros are dangerous.
When you do "constrain(random(0,30)-3, 0, 100)" it expands to:
(random(0,30)-3 < 0 ? 0 : ((random(0,30)-3) > 100 ? 100 : random(0,30)-3)
It calls random (up to) three times, and if the first two are in-range, it will return the third random number.
Grr. This should probably be a c++ template function; I hear that they're just the thing for fixing this!
westfw:
There is at least one problem with the template version. Just a minute ... I'll see if I can find the thread ...
