Problem with Constructor in libraries
Hi
I have trouble to convert the C++ driver for a Digital Tsic Temperature Sensor to Arduino.
I've worked a lot and it's almost done but one error with the Constructor.
error:
In function 'void setup()':
error: expected unqualified-id before '.' token In function 'void loop()':
I used the instrucktion on: http://www.arduino.cc/en/Hacking/LibraryTutorial
But I'm not sure.... I've play around but couldn't get it to work (see out-Commented code).
I think I need a Constructor.
-> in Sketch,
-> tsic.h,
-> tsic.cpp
how can I do that?????
Sketch:
#include <tsic.h>
//tsic tsic1(12, 13);  //firstPin = VCC, secondPin = Signal
void setup(){
//TSIC_INIT();
tsic.TSIC_INIT();          // set data direction of IO-Pins
void loop(){
    returnvalue = getTSicTemp(&temperatur);  // pull the TSIC-Sensor
    // conversion equation from TSic's data sheet
    Temp_celsius = ((float)temperatur / 2047 * 200) - 50;
tsic.h
#ifndef tsic_H
#define tsic_H
#include <inttypes.h>
#include "WProgram.h"
class tsic {
public:
      //tsic(int Pin_VCC, int Pin_Sig);
      void TSIC_INIT();
      uint8_t getTSicTemp (uint16_t *temp_value16);
private:
#endif
tsic.cpp
#include "tsic.h"
extern "C" {
  #include <stdio.h>  //not needed yet
  #include <string.h> //needed for strlen()
  #include "WConstants.h"  //all things wiring / arduino
//defines:
#define TSCI_POWER_PIN 12                 // Where TSIC-Sensors VCC is connected
#define TSIC_SIGNAL_PIN 13            // Where TSIC-Sensors "Signal"-Pin is connected
#define TSIC_ON()                  digitalWrite(TSCI_POWER_PIN, HIGH)      // Power up the TSIC-Sensor
#define TSIC_OFF()                  digitalWrite(TSCI_POWER_PIN, LOW)      // Power down the TSIC-Sensor
#define TSIC_SIGNAL_HIGH      digitalRead(TSIC_SIGNAL_PIN)            //if TSIC_SIGNAL_PIN is high (=1)
#define TSIC_SIGNAL_LOW            !digitalRead(TSIC_SIGNAL_PIN)            //if TSIC_SIGNAL_PIN is low  (=0)
//Variablen:
uint8_t returnvalue;  // return value of getTSicTemp(*temp);
uint16_t temperatur;  // 11-bit temperature value
uint8_t Temp_celsius; // converted temperature in °C
//Konstrucktor
/*tsic::tsic(int Pin_VCC, int Pin_Sig)
      #define TSCI_POWER_PIN Pin_VCC                 // Where TSIC-Sensors VCC is connected
      #define TSIC_SIGNAL_PIN Pin_Sig            // Where TSIC-Sensors "Signal"-Pin is connected
void tsic::TSIC_INIT() {
  pinMode(TSCI_POWER_PIN, OUTPUT);            // sets the digital pin as output
  pinMode(TSIC_SIGNAL_PIN, INPUT);      // sets the digital pin as input
uint8_t tsic::getTSicTemp (uint16_t *temp_value16) {
  uint16_t temp_value1 = 0;
  uint16_t temp_value2 = 0;
  uint8_t i;
  uint16_t Temperature;
  uint8_t parity;
  TSIC_ON();
  delayMicroseconds(60);  // wait for stabilization
  while (TSIC_SIGNAL_HIGH); // wait until start bit starts
  // wait, TStrobe
  while (TSIC_SIGNAL_LOW);
  // first data byte
  // read 8 data bits and 1 parity bit
  for (i = 0; i < 9; i++) {
    while (TSIC_SIGNAL_HIGH);              // wait for falling edge
    if (TSIC_SIGNAL_HIGH)
        temp_value1 |= 1 << (8-i);         // get the bit
        while (TSIC_SIGNAL_LOW);           // wait until line comes high again
  // second byte
  // wait, TStrobe
        temp_value2 |= 1 << (8-i);          // get the bit
  TSIC_OFF();                               // switch TSic off
  // check parity for byte 1
  parity = 0;
    if (temp_value1 & (1 << i))
        parity++;
  if (parity % 2)
  return 0;
  // check parity for byte 2
  parity = 0;
    if (temp_value2 & (1 << i))
        parity++;
  if (parity % 2)
        return 0;
  temp_value1 >>= 1;                 // delete parity bit
  temp_value2 >>= 1;                 // delete parity bit
  Temperature = (temp_value1 << 8) | temp_value2;
  *temp_value16 = Temperature;
  return 1;                       // parity is OK
the original whole C++ file:
*  AVR Code example to read a TSIC-206 / TSIC-306 digital temperatur probe
*  Based on C++ Samplecode in
*  "Tech Notes - ZACwireTM Digital Output, Rev. 2.3, October 17, 2006"
*  Tested with ATMega8, avr-gcc (GCC) 4.3.0 and a TSIC-206
*  see also discussion at http://www.mikrocontroller.net/topic/82087
#define F_CPU 8000000UL    // Clock of target system
#include <avr/io.h>
#include <util/delay.h>
* Hardware Connection of the TSIC-Sensor
#define TSIC_PORT             PORTD  // Port to use
#define TSIC_PIN              PIND
#define TSIC_PORT_DDR         DDRD
#define TSCI_POWER_PIN        PD6    // Where TSIC-Sensors VCC is connected
#define TSIC_SIGNAL_PIN       PD7    // Where TSIC-Sensors "Signal"-Pin is con.
* FUNCTION MACROS
// Define TSCI_POWER_PIN as output, TSIC_SIGNAL_PIN as input
#define TSIC_INIT()           { TSIC_PORT_DDR |= (1<<TSCI_POWER_PIN); \
                              TSIC_PORT_DDR &= ~(1<<TSIC_SIGNAL_PIN); }
#define TSIC_ON()             TSIC_PORT |=  (1<<TSCI_POWER_PIN)
#define TSIC_OFF()            TSIC_PORT &= ~(1<<TSCI_POWER_PIN)
//#define TSIC_SIGNAL           (TSIC_PORT &   (1<<TSIC_SIGNAL_PIN))
// Low/High Signal of the TSIC-Sensor, e.g. "if(TSIC_SIGNAL_HIGH)..."
#define TSIC_SIGNAL_HIGH      TSIC_PIN & ( 1 << TSIC_SIGNAL_PIN )
#define TSIC_SIGNAL_LOW       !( TSIC_PIN & ( 1 << TSIC_SIGNAL_PIN ))
* Function    :   getTSicTemp(*temp_value16);
* Description :   reads from the TSic its output value
* Parameters  :   pointer for return value
* Returns     :   1: reading sucessfull, 0: parity error
uint8_t getTSicTemp (uint16_t *temp_value16) {
  uint8_t i;
  uint8_t parity;
  TSIC_ON();
  _delay_us(60);  // wait for stabilization
  _delay_us(60);
  // wait, TStrobe
  // first data byte
    _delay_us(60);
  // second byte
  // wait, TStrobe
    _delay_us(60);
  parity = 0;
        parity++;
  if (parity % 2)
  return 0;
  parity = 0;
        parity++;
  if (parity % 2)
        return 0;
* Test application
int main (void) {
  while(1){
thanks for Comments!!
The Post was totally edited, so the next 3 Answers don't don't fit anymore
the C++ Code did not work at all!
How can I change that to work??
What the reason for commenting
//TSIC_INIT();
out? :slight_smile:
