I have build a controller to open and close a valve when there is a 10 degree(celsius) colder in the tank from the thermometer placed near the heat pump, then if this condition is true it need to turn on a relay that controls a valve.
For reading the temperature i have 2 DS18B20's
Hope someone out there can help me because this has troubled me the last few days.
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 10
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress tankThermometer, pumpThermometer;
int RelayPin = 4;
int failpin = 13;
boolean Running = false;
boolean fail = false;
float TempOpen;
float TempEt;
float TempTo;
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
//Setting outputs to led and relay
pinMode(RelayPin, OUTPUT);
pinMode(failpin, OUTPUT);
// Start up the library
sensors.begin();
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// assigns the first address found to pumpThermometer
if (!oneWire.search(pumpThermometer)) Serial.println("Unable to find address for outsideThermometer");
// assigns the seconds address found to tankThermometer
if (!oneWire.search(tankThermometer)) Serial.println("Unable to find address for insideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(pumpThermometer);
Serial.print("Device 1 Address: ");
printAddress(tankThermometer);
// set the resolution to 12 bit
sensors.setResolution(pumpThermometer, TEMPERATURE_PRECISION);
sensors.setResolution(tankThermometer, TEMPERATURE_PRECISION);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(pumpThermometer), DEC);
Serial.print("Device 1 Resolution: ");
Serial.print(sensors.getResolution(tankThermometer), DEC);
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
// zero pad the address if necessary
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
Serial.print("Temp C: ");
Serial.print(tempC);
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress)
Serial.print("Resolution: ");
Serial.print(sensors.getResolution(deviceAddress));
// main function to print information about a device
void printData(DeviceAddress deviceAddress)
Serial.print("Device Address: ");
printAddress(deviceAddress);
Serial.print(" ");
printTemperature(deviceAddress);
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures();
Serial.println("DONE");
// print the device information
printData(tankThermometer);
printData(pumpThermometer);
//Getting temperatures
TempEt = sensors.getTempC(tankThermometer);
TempTo = sensors.getTempC(pumpThermometer);
//Doing some math
TempOpen = TempEt + 10;
//Measuring for fails
if(TempEt == -127.00 || TempTo == -127.00){
fail = true;
digitalWrite(failpin, HIGH);
else{
fail = false;
digitalWrite(failpin, LOW);
//Checking when to open
if(TempOpen <= TempTo && Running == false && fail == false){
Running = true;
digitalWrite(RelayPin, LOW);
Serial.println("Relay On");
//Checking when to close
if(TempEt >= TempTo && Running == true && fail == false){
Running = false;
digitalWrite(RelayPin, HIGH);
Serial.println("Relay Off");
StyringOS.ino (4.06 KB)
