Problem with controlling mouse movements using a flex sensor and a potentiometer
Hi, I'm a beginner and figured that starting off with a pre-exisiting project would help understand concepts from the ground up.
So I chose to do a simple game controller (Specifically to play angry birds) using a flex sensor and a potentiometer.
LINK: Angry Bird Game Controller using Arduino, Flex Sensor and Potentiometer
So basically after I copy/pasted and followed instructions, I found that it didn't really work. I began to dig through the code and kinda understood some stuff. At first execution the mouse cursor was just stuck. I modified the code a little bit as far as I could understand and actually got the flex sensor to take care of the movement along the x-axis. But I'm stumped with the pot. The flex sensor detects pressure and is used as to register clicks and pull back the bird following which the y-axis is to be manipulated to set the direction for the it.
My problem I think is that once a click is registered, I am unable to read the updated values from the pot. Any guidance would be helpful!
The original code for the project is given in the link above, and here is the code that I modified a bit.
Arduino Code:
  Serial.begin(9600); //Transmit at 9600 Baud Rate
boolean Mclick = false;
  int potValue = analogRead(A0); //variable to store potValue
  int FlexValue = analogRead(A1); //variable to store Flex Value
  //Serial.print("Flex: ");
  //Serial.println(FlexValue);
  //Serial.print("POT: ");
  //Serial.println(potValue);
  if (FlexValue>=600 && FlexValue<=675) //my flex sensor range
   FlexValue = map (FlexValue,600,675,0,100);  //based on bending convert to 0 to 100
  if (FlexValue>=40)
   Mclick=true;
   Serial.write(1);  //1 is sent to make mouse left click
   Serial.write(FlexValue); //Flex value is the distance to move mouse in X direction
   delay(5000);         //added these 3 lines to original code
   Mclick=false;
   Serial.write(0);
  Mclick=false;
  Serial.write(0);}
  Mclick=false;
  Serial.write(0);}
 if (potValue<=2000)
  potValue = map(potValue,0,1024,101,201); //Based in turn convert to 101 to 201
  Serial.write(potValue); //Pot value is the distance to move mouse in Y direction
  delay(500);     //stability delay
Processing Code:
import java.awt.*;
import java.awt.event.*;
import processing.serial.*;
Serial port;
int data,a,b;
int Pull, Turn, crntX, crntY;
boolean click;
Robot robot;
PFont pfont;
Point save_p;
  size(320, 240);
  port = new Serial(this,Serial.list()[0],9600); //Read the serial values from 0th COM (llok for device manager on your computer to modify this)
  println((Object[])Serial.list()); //COM ports are listed for reference
  try {
    robot = new Robot();
    robot.setAutoDelay(0);
  catch (Exception e) {
    e.printStackTrace();
  pfont = createFont("Impact", 32);
void draw() {
  background(#ffffff);
  fill(#000000);
   if (port.available()>0)
    data=port.read();
    println(data); //Read the data from COM port and save it in data
  if (data>=101 && data<=201) //If the value if from 101 to 201 then it must be from Potentiometer
    Turn = int (map (data,101,201,0,100)); //USe that value to turn the catapullt
  if (data>=5 && data <=100)  //If the value if from 5 to 100 then it must be from Flex Sensor
  { Pull = int (map(data,5,100,0,100));} //USe that value to pull the catapullt
  if (data == 1)
  click = true; //USe that value to press the mouse button
  if (data == 0)
  click = false; //USe that value to release the mouse button
  Point p = getGlobalMouseLocation();
  textFont(pfont);
  text("now x=" + (int)p.getX() + ", y=" + (int)p.getY(), 10, 32); //display the position of X and Y
  text ("Pull =" + Pull, 10,100); //Display the value fo pull (Flex Sesnor)
  text ("Turn =" + Turn, 10,150); //Display the value fo Turn (Potentiometer)
  text ("Click =" + click, 10,200); //Display the status of mouse click
   if (click == false) //when Flex Sesnor is not pulled
  crntX = (int)p.getX() ; crntY = (int)p.getY() ;
  //if (Pull>50)
  robot.mouseRelease(InputEvent.BUTTON1_DOWN_MASK); //Release the mouse button
  if (Pull<5)
  if (click == true) //when Flex Sesnor is pulled
   robot.mousePress(InputEvent.BUTTON1_DOWN_MASK); //Press the mouse Button
   robot.mouseMove(crntX-Pull, crntY+Turn); //Move the mouse based on the Flex and POT value
  Point getGlobalMouseLocation() {
  PointerInfo pointerInfo = MouseInfo.getPointerInfo();
  Point p = pointerInfo.getLocation();
  return p;
PS: Most of the modifications I did were just on the range that our sensors and pot differed by in the map function.
Instead of engaging a forum to reverse engineer someone else's approach to the Angry Birds controller, how would you make the controller? How would you interact with it? How would you get the rubber band to pull back? how would you set the aim up or down? How would you lay this out in your own code?
You should probably NOT add a five second delay in the sketch if you want it to be at all responsive. What didn't work when you were using the original code? I suspect you fixed it incorrectly.
The flex senor range and the pot range from the original post were different form mine, so I made the right changes in the map function. Even after that I couldn't control and change the pot values while the flex sensor click was registered.
Lemon12131:
Probably because you ignore all inputs for five seconds each time the flex sensor click is registered.
