Problem with conversion from const boolean to boolean
Hello everyone I'm just starting with arduino and I have to my project. I would like to have 4 RGB leds switch colors simultaneously and then compare if one of the RGB's has the same color as another I get a point. For the moment I have this code but I keep getting these invalid conversion errors when I try to add more RGB's at the bottom of my code.
//RGB LED pins
int ledDigitalOne[] = {11, 10, 9};
int ledDigitalTwo[]={6,5,3};
int ledDigitalThree[]={A0,A1,A2};
int ledDigitalFour[]={A3,A4,A5};
const boolean ON = 255;
const boolean OFF = 0;
//voorafbepaalde kleuren
const boolean RED[] = {ON, OFF, OFF};
const boolean GREEN[] = {OFF, ON, OFF};
const boolean YELLOW[] = {ON, ON, OFF};
const boolean CYAN[] = {OFF, ON, ON};
const boolean MAGENTA[] = {ON, OFF, ON};
// vooraf bepaalde kleuren in array steken
const boolean* COLORS[] = {RED, GREEN, YELLOW, CYAN, MAGENTA};
//hiermee worden de huidige kleuren opgeslaan om dan te vergelijken
int colorRGB1;
int colorRGB2;
int colorRGB3;
int colorRGB4;
//punten van het spel
int punten;
void setup(){
Serial.begin(9600);}
void loop(){
randomColor();
//hier controleren of kleuren dezelfde zijn
if (colorRGB1==colorRGB2){
punten+=1;}
if (colorRGB1==colorRGB3){
punten+=1;
if (colorRGB1==colorRGB4){
punten+=1;
if (colorRGB2==colorRGB3){
punten+=1;
if (colorRGB2==colorRGB4){
punten+=1;
if (colorRGB3==colorRGB4){
punten+=1;}}
void setColor(int* led, boolean* color){
for(int i = 0; i < 3; i++){
analogWrite(led_, color*);}}_
void randomColor(){
_
int rand = random(0,sizeof(COLORS) / 2); //random nummer van kleuren in array*_
* colorRGB1=rand;*
* setColor(ledDigitalOne, COLORS[rand]); *
* delay(1000);}*
Your code compiles without errors...
can you explain what goes wrong exactly?
Look at the code in the post. Near the end, there is a line:
analogWrite(led*, color);}}*
Why does it turn into italics halfway through this line? Please the post at the top of the list of threads named "How to use this forum".
You write
surely a boolean can have values only of 0 or 1....
regards
Allan
Like Chris said... something happened in your post in this section of your code:
 analogWrite(led, color);}}
I'm sure you have an array being indexed by i that got interpreted as a forum italics command. If you post your code in the code blocks, it will display correctly for us to see.
Hint: use the </>
And for us to really help, (as Kevin said), you'll need to tell us what type of error you get. Can you post it?
Also - you're writing Boolean values to your LED with an analogWrite. Do you mean to use integers and digitalWrite?
allanhurst:
false or true.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
I believe the OP is scared off.
