Problem with data input algorithm
Hi, i’m currrently working on a simple project. The idea is inputting 4 numbers one by one from the keypad. When you hit ’ * ', the lcd will be cleared. When ’ # ’ is hit, the lcd will print “the number is” followed by the 4 numbers inputted before. If the number inputted is more than 4 numbers, the lcd will be cleared up as well. Here is the code I build myself
#include <Keypad.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
int count, val, c;
int order[4];
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {13, 12 , 11, 10}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6 ,7, 3, POSITIVE);
void setup(){
  lcd.begin(16,2);
  lcd.clear();
void loop(){
  char key = customKeypad.getKey();
  if (key != NO_KEY){
    if (key != '#'){
       order[count]=key -'0';
       lcd.setCursor(count,0);
       lcd.print(order[count]);
        count=count+1;
        if (count>4){
          lcd.clear();
          count=0;
    else if(key = '*'){
      count=0;
      lcd.clear();
      lcd.setCursor(0,0);
    else if(key= '#'){
      for(count=0; count<4;){
        val=order[count]+10^(3-count)+c;
        c=val;
        count=count+1;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("value is ");
      lcd.setCursor(0,1);
      lcd.print(val);
      count=0;
I got some problem once i uploaded to the arduino:
  1. Instead of being cleared, the LCD prints " -6" when ’ * ’ is hit. When i keep hitting the ’ # ', the number printed on lcd is different and i dont have any idea where the number is coming from
  2. When ’ # ’ is hit, the lcd turns blank and show nothing.
If I made any program failure, please tell me. Im a newbie, thanks
  • is not #. So it never looks at the * option.
Also remember to use == as the comparison operator.
MorganS: * is not #. So it never looks at the * option.
My mistake, I mean "I keep hitting ' * ' ", not ' I keep hitting ' # '
Why to use clear() in setup if before that nothing was printed?
surepic: Why to use clear() in setup if before that nothing was printed?
I thought it will be better if I used lcd.clear() to make sure everything's blank, But if it's unnecessary, i'd like to remove it from the code
If I may, I suggest using switch/cases for your program. Implement like this:
   char key = customKeyPad.getKey();
   if (key != NO_KEY) {
      switch(key) {
         case '#': {
         //handle key '#' here
          case '*': {
          //handle key '*' here
           default: {
           //handle other keys here
This way, it is easier to debug.
I have my problems solved. Thanks everyone for helping me. I think i’d like to sahre my codes in case of having a same problem and working with those data input algorithms. Thanks everyone
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
#include <Wire.h>
int count, val, c = 0 ;
int order[4];
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
/* =================keyboard========================= */
void setup(){
  lcd.begin(16,2);
  lcd.clear();
void loop(){
  if (key != NO_KEY){
    switch(key){
      case '#':{
        if(count!=4){
          lcd.print("REQUIRED");
      lcd.clear();
      lcd.setCursor(0,0);
      for(int i=0;i<4;){
        val = (order[i]*pow(10,3-i))+c;
        c=val;
        i=i+1;
     lcd.print ("INPUT : ");
     lcd.print(val+1);
     delay(2000);
     lcd.clear();
     lcd.setCursor(0,0);
     val = 0;
     count = 0;
     c = 0;
     case '*':{
      count=0;
      lcd.clear();
      lcd.setCursor(0,0);
   default: {
      count=count+1;
       if (count>4){
        lcd.clear();
        lcd.setCursor(0,0);
        count=0;
