Problem with database
Can somebody help me how to change form saving data from real time, or make my database can stored old data.
I use Firebase and it can store real time only. I had crush hoe to change to make it store old data.
/*  Libraries used:-
                       1. Firebase arduino master => https://github.com/FirebaseExtended/firebase-arduino
                       2. Arduino JSON => https://github.com/bblanchon/ArduinoJson/tree/5.x
#include <ESP8266WiFi.h>
#include<FirebaseArduino.h>
#define FIREBASE_HOST "water-level-sensor-b2f64.firebaseio.com"           // Enter database HOST without "https:// "  and "/" at the end of URL
#define FIREBASE_AUTH "Ienca4392dnxRUz9WR5NwDHgObDXBlWppYj5KFRv"   // Real-time database secret key here
#define WIFI_SSID "Siapakau"            // WIFI SSID here
#define WIFI_PASSWORD "aminnakmakanlagilapar"        // WIFI password here
int level = 0, motor = 0, count = 0, val = 0, man = 0, tmp;
// define pin numbers for ultrasonic sensor
const int trigPin = D7;
const int echoPin = D8;
const int motorPin = D5;
// defines variables for ultrasonic sensor
long duration;
int distance;
int lvlmax = 2; // maximum desired water level i.e.(tank height in cm - 2 cm) {ex. 10 - 3 = 7 cm}
int lvlmin = 8; // minimum desired water level i.e.(tank height in cm - 8 cm) {ex. 10 - 8 = 2 cm}
int lvlone = 6; // margin of level 1
int lvltwo = 5; // margin of level 2
int lvlthree = 3; // margin of level 3
  Serial.begin(9600); Serial.println("Communication Started \n\n");
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT);// Sets the echoPin as an Input
  pinMode(motorPin, OUTPUT);//  Sets the motorPin as an Output
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);                                     //try to connect with wifi
  Serial.print("Connecting to ");
  Serial.print(WIFI_SSID);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    delay(5000);
  Serial.print("Connected to ");
  Serial.println(WIFI_SSID);
  Serial.print("IP Address is : ");
  Serial.println(WiFi.localIP());    //print local IP address
  delay(3000);
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH); delay(300);       // connect to firebase
  // Firebase Error Handling ************************************************
  if (Firebase.failed())
    Serial.println(Firebase.error());
    delay(10);
    Serial.println("Error connecting firebase!");
    count++;
    if (count == 10)
      count = 0;
      ESP.reset();
    return;
    Serial.println("Everything is ready!");
    delay(300); Serial.println("Everything is ready!");
    delay(300);
  // ULTRASONIC *****************************************
  // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(100);
  Serial.println("Trigger for 10 \n\n");
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  Serial.println("duration calculated \n\n");
  Serial.println("assembling sonar\n\n");
  // Calculating the distance
  distance = duration * 0.034 / 2;
  // Prints the distance on the Serial Monitor
  Serial.print("Distance: ");
  //String firebaseDistance = String;
  Serial.println(distance); delay(100);
  if (distance >= lvlmin)
    level = 0;
    motor = 1;
    Firebase.setFloat("/S_HO_C_K/level", level);
    Serial.println("Water below desired level. Motor turned ON.\n\n\n");
    motor = 1;
    digitalWrite(D5, HIGH);
    Firebase.setFloat("/S_HO_C_K/motorstatus", motor);
  delay(5);
  if (distance >= lvlone && distance < lvlmin)
    if (motor == 0)
      level = 11; // checking ON - OFF at mid levels
    if (motor == 1)
      level = 31;
    Serial.println("Water level 1.\n\n\n");
  delay(5);
  if (distance == lvltwo)
    if (motor == 0)
      level = 12;
    if (motor == 1)
      level = 32;
    Serial.println("Water level 2.\n\n\n");
  if (distance >= lvlthree && distance < lvltwo)
    if (motor == 0)
      level = 13;
    if (motor == 1)
      level = 33;
    Serial.println("Water level 3.\n\n\n");
  if (distance <= lvlmax)
    level = 4;
    motor = 0;
    digitalWrite(D5, LOW);
    Serial.println("Water above desired level. Motor turned OFF.\n\n\n");
  val = Firebase.getString("/S_HO_C_K/man").toInt();
  man = val;
  // Manual option *******************************************
  if (man == 1)
    while (1)
      Serial.println("Welcome to Manual Mode. Motor turned ON.\n\n\n");
      level = 2;
      motor = 1;
      Firebase.setFloat("/S_HO_C_K/level", level); // turned on motor
      if (man == 0)
        motor = 0;
        Firebase.setFloat("/S_HO_C_K/man", man);
        delay(100);
        Serial.println("Exit Manual Mode. Motor turned OFF.\n\n\n");
        return;
      // Calculateing distance in manual mode
      Serial.println("Manual mode. duration calculated \n\n");
      Serial.println("Manual mode. assembling sonar\n\n");
        if (motor == 0)
        if (motor == 1)
          level = 31;
        Serial.println("Manual Mode. Water level 1.\n\n\n");
        if (motor == 0)
          level = 12;
        if (motor == 1)
          level = 32;
        Serial.println("Manual Mode. Water level 2.\n\n\n");
        if (motor == 0)
          level = 13;
        if (motor == 1)
          level = 33;
        Serial.println("Manual Mode. Water level 3.\n\n\n");
        level = 4;
        man = 0;
        motor = 0;
        Serial.println("Manual Mode. Water above desired level. Motor turned OFF.\n\n\n");
      tmp = Firebase.getString("/S_HO_C_K/man").toInt();
      man = tmp;
