I´m trying to use the Date and time library, for NTP synchronization purposes.
My problem is related with the libraries. The Date and time library uses <UdpBytewise.h>, which in turn uses the <w5100.h>, <socket.h> and <types.h>.
Does anyone know where i can find the 3 last .h files?
Has anyone used the Date and time library, how did you fixed this?
Best regards
Check - Arduino Playground - DS1307OfTheLogshieldByMeansOfNTP -
I've made it for a logshield but you can strip out the NTP part quite easily
Hi robillart,
Seems to work!
But i have some doubts, from where do you use the DateTime Type definition.
Can you give me that library?
Thanks
Somewhere in the code there is a conversion to unix time (since 1-1- 1970) That number can be used in the DateTimelib IIRC
I didn´t understood completely.
Can you point me the directory of the DateTime.h library.
cheers
Check - Data-Logger Shield for Arduino - The RTC lib has a DateTime class and a 1307 class
