Problem with DC motor from RC Car ( Re.el speed generation)
Hi All,
I have just bought a little RC buggy, it is powered by two AA batteries.
I took the motor out and I tried to connect it to arduino; however, none of the following procedures work
Potentiometer
L293D
A bounces of modified codes based on the previous two methods
Strange thing, at least for me, is that using a dc motor provided by Elegoo (the one that you can find in an arduino sensors kit) all of the above methods work.
When I connect the motor to the current or back to the rc machine, it work just fine.
I'm working with an Arduino nano and this is a picture of the dc motor: it is produced by Chaoli and I cannot find the specs neither online or the instructions of the rc car.
What am I missing?
Thank you for your help.
CronosVirus00:
What am I missing?
I don't know what you are missing, but we are missing ...
  • your program and
  • your wiring diagram
An L293 needs at least 4.5v and it is not an efficient device. If you need to work with 3v then the Pololu DRV8833 would be suitable.
...R
My programs are the same from the example provided, the same goes for the sketches. I powered the motor with both 9v and 3v.
Schemes:
Potentiometer
L293D
Sorry, but if you want help here then post YOUR program (i.e. the code YOU uploaded to your Arduino) and YOUR wiring diagram (i.e. a drawing that you made yourself from looking at your project) here.
I am not going to struggle through two Instructables projects on your behalf.
...R
Alright, I wrote this simple code that turn on the dc motor for a second and turn it off for another second.
PIN (arduino nano):
motor + --> pin 9
motor - ---> GND
#define motorOutput 9
pinMode(Pin, OUTPUT);
digitalWrite(motorOutput, HIGH);
digitalWrite(motorOutput, LOW);
The code works with the DC motor provided with the arduino kit; yet, it does not work with the DC motor from the RC car.
Moreover, the RC car motor does not make any High frequency sound (which in others posts seems to be a common thing). It makes noises only when connected to +6v.
Even with the analogWrite method, the RC car motor does not work, while it works with the kit motor.
PIN (arduino nano):
motor + --> pin A0
motor - ---> GND
pinMode(motorOutput, OUTPUT);
for (int i = 0; i <= 255; i++){ // it gains power slowly
analogWrite(motorOutput, i);
delay(50);
CronosVirus00:
You also need to post diagrams showing how you have everything connected in the two different cases. Photos of simple pencil drawings will be best and no artistic skill is expected. See this Simple Image Guide
...R
Here the schematics for both examples:
You can't drive a motor from an Arduino I/O pin. You will most likely damage your Arduino. The absolute max current from an I/O pin is 40 mA and 20mA would be a lot more sensible. Even a very small motor probably needs 10 or 40 times that amount of current.
You need either a transistor or a motor driver between the Arduino and the motor and a separate power supply for the motor. If you only want the motor to move in one direction a transistor would probably be sufficient.
...R
It works!
I bought the transistor and it works just fine! Thank you.
I followed these
(just ignore the button) with the sketches posted above.
