I have a project which uses deep sleep to save battery.
The wake up is triggered by an interrupt (falling edge on pin 2). It works ok but I discovered that if pin 2 is down (LOW) in the moment the processor goes to sleep, the wake up is never triggered.
I solved the problem by checking the pin is HIGH before seeping, but I think there must be a better solution.
Why do you have to do anything when the pin is LOW? Certainly, delay() is not the thing to do.
This is what I'm asking. Describing the situation: I have a pushbutton connected to pin2 and GND. I've activated the pin2 pullup. When you push the button, the program plays a tone and calls the "gotosleep" function. When you press again the button, the sywtem wakes up. All ok until now.
The problem: if you press the button and keeps it pressed, the processog goes to sleep but you can never wake up it again, even pressing the button.
I added this line to avoid it and it works, but I think it should be a better solution. A key bounce could produce the same situation and other sensor input could produce the same problem. Then, I want to find a better solution for the future.
while(digitalRead(2)==LOW)
// Doing nothing
Ah! I added the delay for avoiding contact bounces. Otherwise, the digitalRead could read a HIGH value but some microseconds later the value could be LOW and produce the described problem.
