I'm working on my first Arduino project and I've run into a problem. I'm trying to produce a square wave at a specific frequency on pin 8 of the Arduin Digital (PWM). Initially I used delayMicroseconds(), which seemed to work fine until I realized that I may want an interval longer than 16mSec.
I've tried using delay() and millis() but neither seems to work- after uploading the file the output goes low, I see a single cycle, and then the output remains low (no square wave).
Arduino IDE v1.8.13
Arduino Uno
This is the code I'm running. All three methods for producing the delay have been included (with the two that don't work being commented out). What am I doing wrong?
int LEDpin = 13;
int CH1pin = 8;
int times = 100;
int chan = 1;
int duration = 1;
unsigned long time_now = 0;
int main() {
pinMode(LEDpin, OUTPUT);
pinMode(CH1pin, OUTPUT);
time_now = millis();
while (times == 100)
digitalWrite(CH1pin, LOW);
delayMicroseconds(duration);
//delay(duration);
//while(millis() < time_now + duration){
digitalWrite(CH1pin, HIGH);
//delay(duration);
"This function works very accurately in the range 3 microseconds and up. We cannot assure that delayMicroseconds will perform precisely for smaller delay-times."
I was hoping to be able to set the delay from 1mSec to 100mSec. I just don't understand why delayMicroseconds() works but delay() and millis() doesn't.
It probably isn't the cause of your problem, but while you're looking at this, it's worth mentioning that this is a flawed statement.
You should never compare millis() to a future time stamp. It will not work correctly when millis() rolls over. You need to subtract millis() from the time stamp, and compare the result with a value
Yes, I was hoping to switch to delay() because I read that the delayMicroseconds() command doesn't work beyond delayMicroseconds(16000). The range I was shooting for is 1millisecond to 100milliseconds.
