problem with delay - processing
I send messages from the board to processing - i send a 1, 2 or 3. i know this works because i trace in the wiring console.
i setup the processing code below to change color of square every second based on number sent from board. it works but something wrong with delay. instead of taking 1 second, it takes much longer… is there something wrong with my code thats causing this?
import processing.serial.*;
Serial port;
int val;
size(200, 200);
noStroke();
framerate(10);
println(Serial.list());
port = new Serial(this, Serial.list()[1], 9600);
void draw()
if( 0 < port.available() )
val = port.read();
background(#222222);
if( val == 1 )
fill(#00FF43);
print("\n");
print(val);
}else if( val == 2 ){
fill(#FFBF00);
print("\n");
print(val);
else if( val == 3 ){
fill(#FF0000);
print("\n");
print(val);
rect(50, 50, 100, 100);
