Sorry, here it is all the code. When I use the digitalWrite function in the set_dio() function it works perfectly, when I change it with the direct manipulation it stops working...it doesnt address the instrument properly.
* GIPB USB Adapter
#include <string.h>
#include <avr/io.h>
#include <avr/wdt.h>
// Define PIN name
#define DIO1 2
#define DIO2 3
#define DIO3 4
#define DIO4 5
#define DIO5 6
#define DIO6 7
#define DIO7 8
#define DIO8 9
#define IFC A5
#define EOI A4
#define DAV A3
#define NRFD A2
#define NDAC A1
#define ATN A0
#define REN GND
#define SRQ 10
// set Commando val
char com[256] = "";
char c = 0;
int p = 0;
unsigned long t;
byte pin;
// initialize the serial device
// initialize gpib line
pinMode(EOI, OUTPUT); digitalWrite(EOI, HIGH);
pinMode(DAV, OUTPUT); digitalWrite(DAV, HIGH);
pinMode(NDAC, OUTPUT); digitalWrite(NDAC, LOW);
pinMode(NRFD, OUTPUT); digitalWrite(NRFD, LOW);
//activate the watch dog with time_out = 2 s
wdt_enable(WDTO_4S);
Serial.println("ELI 1.2 ready!");
int i;
if (Serial.available()) {
c = Serial.read();
*(com + p) = c; *(com + p + 1) = 0;
p++;
if (';' == c) {
*(com + p - 1) = 0;
if (0 == strcmp("IFC", com)) { gpibIFC();
} else if (0 == strcmp("DCL", com)) { gpibDCL();
} else if (0 == strcmp("STA", com)) { gpibLineStatus();
} else if (0 == strcmp("RES", com)) {gpibRestart();
char command;
int addr;
char option[255];
sscanf(com, "%c%2d", &command, &addr);
for (i = 4 ; i < strlen(com) ; i++) {
option[i-4] = *(com + i);
} option[i-4] = 0;
strcat(option, "\r\n");
if ('W' == command) {
t = micros();
gpibTalk((byte)addr, option);
t = micros() - t;
Serial.println("time elapsed: ");
Serial.println(t);
} else if ('R' == command) {
char str[255] = "";
gpibListen((byte)addr, str, "\r\n"); Serial.println(str);
} else if ('C' == command) {
gpibSDC((byte)addr);
*com = 0; p = 0; c = 0;
wdt_reset();
void gpibLineStatus(void) {
pinMode(ATN, INPUT); digitalWrite(ATN, HIGH); Serial.print(" ATN="); Serial.print(digitalRead(ATN));
pinMode(DAV, INPUT); digitalWrite(DAV, HIGH); Serial.print(", DAV="); Serial.print(digitalRead(DAV));
pinMode(NRFD, INPUT); digitalWrite(NRFD, HIGH); Serial.print(", NRFD="); Serial.print(digitalRead(NRFD));
pinMode(NDAC, INPUT); digitalWrite(NDAC, HIGH); Serial.print(", NDAC="); Serial.print(digitalRead(NDAC));
pinMode(EOI, INPUT); digitalWrite(EOI, HIGH); Serial.print(", EOI="); Serial.print(digitalRead(EOI));
Serial.println(", DIO8-1=");
pinMode(DIO8, INPUT); digitalWrite(DIO8, HIGH); Serial.print(digitalRead(DIO8));
pinMode(DIO7, INPUT); digitalWrite(DIO7, HIGH); Serial.print(digitalRead(DIO7));
pinMode(DIO6, INPUT); digitalWrite(DIO6, HIGH); Serial.print(digitalRead(DIO6));
pinMode(DIO5, INPUT); digitalWrite(DIO5, HIGH); Serial.print(digitalRead(DIO5));
pinMode(DIO4, INPUT); digitalWrite(DIO4, HIGH); Serial.print(digitalRead(DIO4));
pinMode(DIO3, INPUT); digitalWrite(DIO3, HIGH); Serial.print(digitalRead(DIO3));
pinMode(DIO2, INPUT); digitalWrite(DIO2, HIGH); Serial.print(digitalRead(DIO2));
pinMode(DIO1, INPUT); digitalWrite(DIO1, HIGH); Serial.println(digitalRead(DIO1));
byte get_dio() {
byte x = 0;
pinMode(DIO1, INPUT); bitWrite(x, 0, !digitalRead(DIO1));
pinMode(DIO2, INPUT); bitWrite(x, 1, !digitalRead(DIO2));
pinMode(DIO3, INPUT); bitWrite(x, 2, !digitalRead(DIO3));
pinMode(DIO4, INPUT); bitWrite(x, 3, !digitalRead(DIO4));
pinMode(DIO5, INPUT); bitWrite(x, 4, !digitalRead(DIO5));
pinMode(DIO6, INPUT); bitWrite(x, 5, !digitalRead(DIO6));
pinMode(DIO7, INPUT); bitWrite(x, 6, !digitalRead(DIO7));
pinMode(DIO8, INPUT); bitWrite(x, 7, !digitalRead(DIO8));
return x;
void set_dio(byte x) {
byte a = x;
byte y;
byte z;
// SET DIO 1-8 OUTPUT
DDRD = DDRD | B11111100;
DDRB = DDRB | B00000011;
x = ~x;
y = x & B11000000;
y = y >> 6;
PORTB = PORTB | y;
z = x << 2;
z = z & B11111100;
PORTD = PORTD | z;
digitalWrite(DIO1, bitRead(~x, 0));
digitalWrite(DIO2, bitRead(~x, 1));
digitalWrite(DIO3, bitRead(~x, 2));
digitalWrite(DIO4, bitRead(~x, 3));
digitalWrite(DIO5, bitRead(~x, 4));
digitalWrite(DIO6, bitRead(~x, 5));
digitalWrite(DIO7, bitRead(~x, 6));
digitalWrite(DIO8, bitRead(~x, 7));
void gpibWrite(byte data) {
// set NRFD and NDAC input, and DAV output
DDRC = DDRC | B00001000;
DDRC = DDRC & B11111001;
// wait until (LOW == NDAC)
while (B11111111 == (PORTC | B11111101)) { ; }
// output data to DIO
set_dio(data);
// wait until (HIGH == NRFD)
while (B11111011 == (PORTC & B11111011)) { ; }
// validate data
PORTC = PORTC & B11110111; //set DAV LOW
// wait until (HIGH == NDAC)
while (B11111101 == (PORTC & B11111101)) { ; }
PORTC = PORTC | B00001000; // set DAV HIGH
set_dio(0);
return;
boolean gpibRead(byte *data) {
boolean ret = false;
// prepare to listen
// wait until (LOW == DAV)
while (HIGH == digitalRead(DAV)) { ; }
// Ready for data
// read from DIO
*data = get_dio();
// check EOI
if (LOW == digitalRead(EOI)) {
ret = true;
ret = false;
// data accepted
// wait until invalid data
while (LOW == digitalRead(DAV)) { ; }
return ret; // return true when EOI==LOW
void gpibTalk(byte addr, char *str) {
// attention
DDRC = DDRC | B00010001; // set EOI and ATN output
PORTC = PORTC | B00010000; // set EOI HIGH
PORTC = PORTC & B11111110; // set ATN LOW
// unlisten
gpibWrite(0x3F);
// talker address
gpibWrite(0x40);
// listener address
gpibWrite((byte)(0x20 + addr));
// end of attention
PORTC = PORTC | B00000001; // set ATN HIGH
// write string
while (0 != *(str + 1)) {
gpibWrite(*str);
str++;
// write last char
PORTC = PORTC & B11101111; // set EOI LOW
gpibWrite(*str);
boolean gpibListen(byte addr, char *str, char* del) {
// attention
pinMode(ATN, OUTPUT);
digitalWrite(ATN, LOW);
// unlisten
gpibWrite(0x3F);
// talker address
gpibWrite((byte)(0x40 + addr));
// listener address
gpibWrite(0x20);
// end of attention
// recieve data
int i, s, len = strlen(del);
byte c;
boolean isLast, isDel;
s = 0;
do {
isLast = gpibRead(&c); *(str) = c;
isDel = true;
for (i = 0 ; i < len ; i++) {
isDel = isDel & (*(str - i) == *(del + len - i - 1));
str++;
} while (!(isLast || isDel));
*(str) = 0;
return true;
void gpibIFC(void) {
pinMode(IFC, OUTPUT); digitalWrite(IFC,LOW); delayMicroseconds(128);
digitalWrite(IFC, HIGH);
void gpibDCL(void) {
// attention
pinMode(ATN, OUTPUT); digitalWrite(ATN, LOW);
// send DCL
gpibWrite(0x14);
// end of attention
void gpibSDC(byte addr) {
// attention
// unlisten
gpibWrite(0x3F);
// send ADDRESS for device clear
gpibWrite((byte)(32 + addr));
// send SDC
gpibWrite(0x04);
// end of attention
void gpibRestart() {
Serial.flush();
pinMode(ATN, OUTPUT); digitalWrite(ATN, HIGH);
