Problem with DS1307, time is completly wrong, unreal time
Hello,
i have a problem with the DS1307. It should print every 3 hours the time and date. But only the first line is correct.
The file looks like that:
Date, Time, Temp1,Humidity1,Temp2,Humidity2,Temp3,Humidity3
2023.12.08,20:07:02, 15.0,83.0,16.0,76.0,18.0,70.0
2032.31.34,32:30:00, 16.0,82.0,16.0,76.0,17.0,74.0
2031.33.34,33:30:00, 16.0,82.0,17.0,77.0,18.0,74.0
2033.33.34,33:30:00, 15.0,88.0,16.0,83.0,17.0,77.0
2033.33.34,33:30:00, 16.0,86.0,17.0,81.0,18.0,77.0
2033.33.34,33:30:00, 17.0,86.0,18.0,81.0,18.0,77.0
If I set the time correctly, it will be written correctly once and then incorrectly...
Can anyone help me to find the problem?
Here is my code:
   Program to demonstrate Data Logging/Visualisation using Arduino
   ###Connection with SD card module###
   Vcc->5V
   Gnd->Gnd
   MISO->pin 12
   MOSI->pin 11
   SCK-> pin 13
   CS-> pin 4
   ###Connection with DS3231###
   Vcc->5V
   Gns->Gnd
   SCL->pin A5
   SDA-> pin A4
   ###Connection with DT11###
   Vcc->5V
   Gnd->Gnd
   Out-> pin 7
#include <RTClib.h> //Library for RTC module (Download from Link in article)
#include <Wire.h>
#include <SPI.h> //Library for SPI communication (Pre-Loaded into Arduino)
#include <SD.h> //Library for SD card (Pre-Loaded into Arduino)
#include <dht.h> //Library for dht11 Temperature and Humidity sensor (Download from Link in article)
#define DHT11_PIN1 7 //Sensor output pin is connected to pin 7
#define DHT11_PIN2 8
#define DHT11_PIN3 6
dht DHT1; //Sensor object named as DHT
dht DHT2;
dht DHT3;
RTC_DS3231 rtc;
const int chipSelect = 4; //SD card CS pin connected to pin 4 of Arduino
  Initialize_SDcard();
  rtc.begin();
  Write_SDcard();
  delay(10800000); //Wait for 5 seconds before writing the next data
void Write_SDcard() {
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  int chk = DHT1.read11(DHT11_PIN1);
            DHT2.read11(DHT11_PIN2);
            DHT3.read11(DHT11_PIN3);
  float t = DHT1.temperature;
  float h = DHT1.humidity;
  float t1 = DHT2.temperature;
  float h1 = DHT2.humidity;
  float t2 = DHT3.temperature;
  float h2 = DHT3.humidity;
  Serial.println(t, 1);
  Serial.println(h, 1);
  Serial.println(t1, 1);
  Serial.println(h1, 1);
  Serial.println(t2, 1);
  Serial.println(h2, 1);
  DateTime now = rtc.now();
  File dataFile = SD.open("LoggerCD.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    char bufer[100];
    sprintf(bufer, "%02u.%02u.%02u,%02u:%02u:%02u,%0u.%0u,%0u.%0u,%0u.%0u,%0u.%0u,%0u.%0u,%0u.%0u\r\n",
//                 YY   MM   DD   hh   mm   ss  t1  t1  h1  h1  t2  t2  h2  h2
            now.year(),
            now.month(),
            now.day(),
            now.hour(),
            now.minute(),
            now.second(),
            uint16_t(floor(t)), uint16_t(t * 10) % 10,
            uint16_t(floor(h)), uint16_t(h * 10) % 10,
            uint16_t(floor(t1)), uint16_t(t * 10) % 10,
            uint16_t(floor(h1)), uint16_t(h * 10) % 10,
            uint16_t(floor(t2)), uint16_t(t * 10) % 10,
            uint16_t(floor(h2)), uint16_t(h * 10) % 10
    dataFile.print(bufer);
    dataFile.close(); //Close the file
    Serial.println("OOPS!! SD card writing failed");
void Initialize_SDcard() {
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  if (dataFile) {
    dataFile.println("Date,Time,Temperatur Ecke,Feuchtigkeit Ecke,Temperatur Schrank,Feuchtigkeit Schrank,Temperatur Bett,Feuchtigkeit Bett"); //Write the first row of the excel file
    dataFile.close();
Are you using a DS1307 or a DS3231?
I never had much luck with the old DS 1307 RTC. They just did not keep good time. I recommend that you get DS3231 RTC or one newer RTC modules.
Post a link to the product page for the DS1307 module, and a photo of your setup.
Make sure that the CH bit in register 0 is cleared, or the clock won't run.
However, as others have said, the DS1307 is a waste of your time.
