Problem with DS18B20 refrech in switch case statement
Hello.
This is my first post here, and english isn't my first language so please forgive me :).
I have a problem with my code.
First my hardware:
  • NodeMCU
  • two DS18B20 sensors attatched to pin D5 and 4k7ohm resistor to 3v
  • OLED display 128x64 ssd1306 i2c
  • momentary switch connected to pin D6 witch 10kohm resistor.
The problem is my temperature won't refresh. Readings do update just if I cycle trough the cases. I've tried using while loop inside case 1 but code stucks there. Could someone push me into right direction?
This is my code:
#include <Wire.h>
#include <SPI.h>
//#include <SimpleTimer.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
//SimpleTimer timer;
#define ONE_WIRE_BUS D5
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
uint8_t sensor1[8] = { 0x28, 0x00, 0xF9, 0xD5, 0x13, 0x19, 0x01, 0x65 };
uint8_t sensor2[8] = { 0x28, 0x47, 0x43, 0xDD, 0x13, 0x19, 0x01, 0x7B };
float temp_1;
float temp_2;
const int buttonPin = 12;
boolean buttonState = LOW;
boolean lastButtonState = LOW;
int Display = 1;
unsigned long lastDebounceTime = 0;
long debounceDelay = 50;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
void setup(){
  pinMode(buttonPin, INPUT);
  DS18B20.begin();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  Serial.println(Display);
  display.setRotation(1);
  display.clearDisplay();
  displayAnimation();
  display.display();
void loop(void){
  int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
    if ((millis() - lastDebounceTime) > debounceDelay) {
      if (reading != buttonState) {
      buttonState = reading;
        if(reading == HIGH){
        Display ++;
          if (Display > 3){
          Display = 1;
        switch(Display){
        case 1:
        while(Display == 1){
        DS18B20.requestTemperatures();
        temp_1 = DS18B20.getTempC(sensor1);
        temp_2 = DS18B20.getTempC(sensor2);
        Serial.println(temp_1);
        Serial.println(temp_2);
        display.drawLine(0,32,64,32,WHITE);
        display.drawLine(0,96,64,96,WHITE);
        display.drawLine(0,64,64,64,WHITE);
        display.setTextSize(2);
        display.setTextColor(WHITE);
        display.setCursor(2, 9);
        display.println(temp_1);
        display.setCursor(2, 41);
        display.println(temp_2);
        display.setCursor(2, 73);
        display.println("--.--");
        display.setCursor(2, 105);
        display.display();
        continue;
        case 2:
        display.println("ekran_2");
        display.display();
        case 3:
        display.println("ekran_3");
        display.display();
 lastButtonState = reading;
Also when I restart NodeMCU, code stops after animation in void setup. Is there a way to move sequention to case 1: immediately after animation without pressing button?
inside case 1 you have a while() loop that will always be true so you will never get out of it.
Use the auto format feature of the IDE (Ctrl-T) so make your code easier to see and understand. It will properly indent things for you.
Thanks for tip, and quick reply:)
While() loop was only for experimenting purpose. When there is only case 1, program will only execute once. My question is, is there a way to refresh temperature readings inside case 1, or somehow exit while() loop after pressing button?
Updated code:
#include <Wire.h>
#include <SPI.h>
float temp_1;
float temp_2;
int Display = 1;
  DS18B20.begin();
  displayAnimation();
  display.display();
  delay(100);
  display.drawLine(0, 32, 64, 32, WHITE);
  display.drawLine(0, 96, 64, 96, WHITE);
  display.drawLine(0, 64, 64, 64, WHITE);
  display.display();
void loop(void) {
      if (reading == HIGH) {
        Display ++;
        if (Display > 3) {
          Display = 1;
        switch (Display) {
          case 1:
            display.display();
          case 2:
            display.println("screen_2");
            display.display();
          case 3:
            display.println("screen_3");
            display.display();
Look at the tutorial Several Things at a Time to see how to structure your code so you are constantly iterating over loop() and only reacting to changes.
Thank you very much blh64! :slight_smile: It works! With one little glitch. On screen_1 DallasTemperature library mesure temperatures from sensors. It takes time, so when I'm on this screen I need to hold button until whole loop execute to switch screen. Is there a way to avoid this?
Updated code:
#include <Wire.h>
#include <SPI.h>
float temp_1;
float temp_2;
int buttonState = LOW;
int lastButtonState = LOW;
int Display = 0;
unsigned long debounceDelay = 50;
  Serial.println("Starting TEST_OLED_5.3");
  DS18B20.begin();
  readButton();
  displayScreen_0();
  displayScreen_1();
  displayScreen_2();
  displayScreen_3();
void readButton() {
        Display ++;
        if (Display > 3) {
          Display = 1;
void displayScreen_0 () {
  if (Display == 0) {
    displayAnimation();
    Display++;
void displayScreen_1 () {
  if (Display == 1) {
    display.display();
void displayScreen_2() {
  if (Display == 2) {
    display.println("screen2");
    display.display();
void displayScreen_3() {
  if (Display == 3) {
    display.println("screen3");
    display.display();
Look at the WaitForConversion example that comes with the library. It shows you how to do a non-blocking request to read the temperatures.
Once again, thank you very much :slight_smile: Everything is working excellect now. Even blynk server and wi-fi clock :slight_smile:
 #include <Wire.h>
#include <SPI.h>
#include <time.h>
#define BLYNK_PRINT Serial
DallasTemperature sensors(&oneWire);
char auth[] = "XXX";
char ssid[] = "XXX";
char pass[] = "XXX";
float temp_1;
float temp_2;
int Display = 1;
int timezone = 1 * 3600;
int dst = 0;
DeviceAddress tempDeviceAddress;
int  resolution = 12;
unsigned long lastTempRequest = 0;
int  delayInMillis = 0;
  displayAnimation();
  Blynk.begin(auth, ssid, pass);
  WiFi.begin(ssid, pass);
  configTime(timezone, dst, "pool.ntp.org", "time.nist.gov");
  sensors.begin();
  sensors.getAddress(tempDeviceAddress, 0);
  sensors.setResolution(tempDeviceAddress, resolution);
  sensors.setWaitForConversion(false);
  sensors.requestTemperatures();
  delayInMillis = 750 / (1 << (12 - resolution));
  lastTempRequest = millis();
  readButton();
  displayScreen_1();
  displayScreen_2();
  displayScreen_3();
  Blynk.run();
  getSendData();
void readButton() {
        Display ++;
        if (Display > 3) {
          Display = 1;
  if (Display == 1) {
    if (millis() - lastTempRequest >= delayInMillis) {
      temp_1 = sensors.getTempC(sensor1);
      temp_2 = sensors.getTempC(sensor2);
      display.setTextSize(1);
      display.setCursor(0, 2);
      display.println("temp_1:");
      display.setCursor(0, 34);
      display.println("temp_2:");
      display.setCursor(0, 66);
      display.println("temp_3:");
      display.setCursor(0, 98);
      display.println("temp_4:");
      display.setCursor(0, 15);
      display.println(temp_1, 1);
      display.setCursor(0, 47);
      display.println(temp_2, 1);
      display.setCursor(0, 79);
      display.setCursor(0, 111);
      display.display();
  if (Display == 2) {
    time_t now = time(nullptr);
    struct tm* p_tm = localtime(&now);
    Serial.print(p_tm->tm_mday);
    Serial.print("/");
    Serial.print(p_tm->tm_mon + 1);
    Serial.print("/");
    Serial.print(p_tm->tm_year + 1900);
    Serial.print(" ");
    Serial.print(p_tm->tm_hour);
    Serial.print(":");
    Serial.print(p_tm->tm_min);
    Serial.print(":");
    Serial.println(p_tm->tm_sec);
    // Clear the buffer.
    display.setTextSize(3);
    display.setCursor(0, 0);
    display.print(p_tm->tm_hour);
    //display.print(":");
    display.setCursor(0, 30);
    if ( p_tm->tm_min < 10)
      display.print("0");
    display.print(p_tm->tm_min);
    display.setCursor(0, 60);
    //display.print(".");
    if ( p_tm->tm_sec < 10)
      display.print("0");
    display.print(p_tm->tm_sec);
    display.setCursor(0, 90);
    display.print(p_tm->tm_mday);
    display.print("/");
    display.print(p_tm->tm_mon + 1);
    display.print("/");
    display.print(p_tm->tm_year + 1900);
    display.display();
    //delay(1000); // update every 1 sec
  if (Display == 3) {
    display.display();
void getSendData() {
    Blynk.virtualWrite(5, temp_1); //virtual pin V5 indoor temp
    Blynk.virtualWrite(6, temp_2); //virtual pin V6 outdoor temp
