Hello guys.
I have a problem with DS3234(Real Time Clock). I'm using DeadOn RTC - DS3234 Breakout by sparkfun. I made this sketch RTC_SPI_for_setup.
It doesn't work well. It shows lots of error like this.
2014/00/05 16:47:00
2014/11/05 04:47:44
2014/00/05 16:47:04
2014/11/05 04:47:46
2014/00/05 16:47:04
2014/11/05 04:47:48
2014/00/05 16:47:00
2014/11/05 04:47:50
2014/00/05 16:47:00
2014/11/05 16:47:52
2014/11/05 16:47:53
2014/11/05 16:47:54
2014/11/05 16:47:55
2014/11/05 16:47:56
2014/11/05 16:47:57
2014/11/05 16:47:58
2014/11/05 16:47:59
2014/11/05 16:48:00
2014/11/05 16:48:01
2014/11/05 16:48:02
I referred to example sketch on sparkfun.
Dose anyone know how to fix the problem??
Thank you so much for your great help!!
RTC_SPI_for_setup
#include <SPI.h>
//chip select = 8, CLK = 13, MISO = 12, MOSI = 11
const int cs=8; //chip select
RTC_init();
//day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
//SetTimeDate(5,11,14,15,51,00); //setup current time
Serial.println(ReadTimeDate());
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE3); // both mode 1 & 3 should work
//set control register
digitalWrite(cs, LOW);
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
digitalWrite(cs, HIGH);
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={s,mi,h,0,d,mo,y};
for(int i=0; i<=6;i++){
if(i==3)
i++;
int b= TimeDate[i]/10;
int a= TimeDate[i]-b*10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate[i]= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate[i]);
String ReadTimeDate(){
String temp;
char timechar[30] = "";
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode
if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate[i]=a+b;
else if(i==4){
TimeDate[i]=a+b*10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate[i]=a+b*10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate[i]=a+b*10;
else{
int b=(n & B01110000)>>4;
TimeDate[i]=a+b*10;
sprintf(timechar, "20%02d/%02d/%02d %02d:%02d:%02d", TimeDate[6],TimeDate[5],TimeDate[4],TimeDate[2],TimeDate[1],TimeDate[0]);
//20yy/mm/dd hh/mm/ss
//I used "sprintf" for arrange number fo digits
temp = timechar;
return(temp);
