Hi.
I have a very strange issue, sorry if i can't explain it well.
I have a program (much bigger than this) that i am making, i noticed that if i make some type of changes in the code it crashes badly, all is tied to the data read from the eeprom!
it seems that it loads the data into the ram in a already used space or something similar.
To use this code and generate the problem do the following:
- Take an Arduino UNO, connect a button from pin 7 to ground (i used input_pullup so a resistor might not be needed, but for safety put one)
- Load the code, open the serial monitor and keep the button pressed, it will save the default structure to eeprom and will ask you to reset the arduino.
Now you will see this in the serial monitor
93 bytes readed
************* LOOP *****************
temperature=30.60 20.00
Bucketname= BucketName
Bucketkey= BucketKey
Accesskey= ********************************
1
2
3
4
5
6
7
8
9
10
11
12
************* LOOP END *****************
And the loop continues ok.
now just comment out the final
Serial.println("************* LOOP END *****************");
Serial.println(" ");
Or/end 2/3 "toSend" lines in the middle, upload, and your sketch will go crazy, from printing erroneous data in the structure and values to totally screwing up and locking!
Now to make it ok you have 2 options, revert the comments, and upload, and it will be ok, or reset and push the button, the struct will be written in the eeprom again and the program will work.
ATTENTION: if you leave the arduino running with the "no good" eeprom loaded code for long it will go really crazy, and to load another sketch you may need to unplug it, or keep it reset while initiating the load process or similar!
For me this is a real problem since i can't/won't rewrite the eeprom every time i do some changes in the code, and since my code is very large (it runs on a mega) it seems to me that also doing other stuff causes this error, like changing big strings...
This is the sketch.
#include <EEPROMex.h>
double temp[2] = {30.60, 20.00};
struct datastructure {
byte conf = 1;
byte dataversion = 3;
byte mac[6] = {0x90, 0xA2, 0xDA, 0x0D, 0xD5, 0xB6};
byte ip[4] = {192, 168, 5, 10};
byte gateway[4] = {192, 168, 5, 3};
byte subnet[4] = {255, 255, 255, 0};
byte mydns[4] = {8, 8, 8, 8};
bool wday[7] = {1, 1, 1, 1, 1, 1, 1};// giorni della settimana per lo schedule dell'ac
bool ahour[24] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0};// 24 hour array
int offtemp = 28;
int ontemp = 28;
int autoontemp = 33;
bool manualac = 0;
bool mute = 1;
String bucketName = "BucketName";
String bucketKey = "BucketKey";
String accessKey = "********************************";
String signalName[2] = {"Reading1", "Reading2"};
datastructure data;
String signalData[2];
EEPROM.setMemPool(0, EEPROMSizeUno);
pinMode(7, INPUT_PULLUP);
eepromDefaults();
int x = EEPROM.readBlock(0, data);
Serial.println((String)x + " bytes readed");
Serial.println("************* LOOP *****************");
signalData[0] = (String)temp[0];
signalData[1] = (String)temp[1];
Serial.print("temperature=");
Serial.print(signalData[0]);
Serial.print(" ");
Serial.println(signalData[1]);
printStructData();
String toSend = "POST /api/events HTTP/1.1\r\n";
Serial.println("1");
toSend += "Host: insecure-groker.initialstate.com\r\n";
Serial.println("2");
toSend += "Content-Type: application/json\r\n";
Serial.println("3");
toSend += "User-Agent: Arduino\r\n";
Serial.println("4");
toSend += "Accept-Version: ~0\r\n";
Serial.println("5");
toSend += "X-IS-AccessKey: " + data.accessKey + "\r\n";
Serial.println("6");
toSend += "X-IS-BucketKey: " + data.bucketKey + "\r\n";
Serial.println("7");
String payload = "[{\"key\": \"" + data.signalName[0] + "\", ";
Serial.println("8");
payload += "\"value\": \"" + signalData[0] + "\"}]";
Serial.println("9");
payload += "\r\n";
Serial.println("10");
toSend += "Content-Length: " + String(payload.length()) + "\r\n";
Serial.println("11");
toSend += "\r\n";
Serial.println("12");
toSend += payload;
// try to comment the following 3 lines after the first upload + eeprom write with the button
delay(2000);
void printStructData(void)
Serial.print("Bucketname= ");
Serial.println(data.bucketName);
Serial.print("Bucketkey= ");
Serial.println(data.bucketKey);
Serial.print("Accesskey= ");
Serial.println(data.accessKey);
void eepromDefaults(void)
if (digitalRead(7) == LOW)
EEPROM.writeBlock(0, data);
Serial.println("Defaults loaded...");
Serial.println("Please reset");
while (1)
//do nothing waiting for the user to reset
