Hey guys! I am an engineering student from Taiwan. Because of school, I am trying to get angle from IC
And this is the board, combines 3 IC(Electronic compass,Gyro,Accelerometer)
But when I use the Electronic compass, which is HMC5883, the value keep on moving up and down about 5 degree even if I am holding the board
it really bothers me because what I need is more accurate value =(
Is my code(Arduino) wrong or this IC's ability problem?
many thanks
void HMC5883_initialize(){
 //Put the HMC5883 IC into the correct operating mode
 Wire.beginTransmission(address); //open communication with HMC5883
 Wire.write(0x02); //select mode register
 Wire.write(0x00); //continuous measurement mode
 Wire.endTransmission();
void HMC5883_get_angle(){
 //Tell the HMC5883 where to begin reading data
 Wire.write(0x03); //select register 3, X MSB register
Â
//Read data from each axis, 2 registers per axis
 Wire.requestFrom(address, 6);
 if(6<=Wire.available()){
  EC_x_angle = Wire.read()<<8; //X msb
  EC_x_angle |= Wire.read(); //X lsb
  EC_y_angle = Wire.read()<<8; //Y msb
  EC_y_angle |= Wire.read(); //Y lsb
  EC_pitch = Wire.read()<<8; //Z msb
  EC_pitch |= Wire.read(); //Z lsb
Magnetic interference from nearby motors, machines, cars, wires and ground signals can cause small disturbances. Take the electronic device out of the city away from cars, into a grassy field. Maybe the noise will be less away from the city.
You can adjust the gain setting in configuration register B. Lower the gain if you can and it will help with noise amplitude. Also, in configuration register A you can set the number of data points that are averaged per reading.
hello groundfungus:
I looked for google tried that, but...I am too new to know how to adjust register
can you kindly show me how to adjust the setting in register A and B?
anyway, thanks for your reply
Wire.beginTransmission(compass); //open communication with HMC5883
 Wire.write(0x01); //select config b reg
 Wire.write(0x40); //set gain
To set up configuration register A write to 0x00 (in place of the 0x01 in above code). Consult the data sheet for the bits that you need to set or clear and send that byte in place of the 0x40 (bits MA0 and MA1 set number of samples averaged).
Write out the bits in binary. The three most significant bits set gain and the five less significant bits are set to zero. To set gain at ±1.9Ga set the register to binary 0100 0000 which is 0x40 hex or if you want 64 decimal . Look a figures 10 and 11 in the data sheet. If you want gain to be ±5.5 you would send binary 1100 0000 or 0xc0 hex or 192 decimal.
