Hi. I am new to your arduino world. I used to play something with arduino, but I don't remember what and how.
Also sorry for my English, it may not be very correct.
Well, I have a problem with entering the code to arm and disarm in two game modes "search and destroy" and "sabotage". The problem is that I can only enter the numbers 3,6,9, pressing the remaining 1,2,4,5,7,8,0 nothing happens. I used code from the Keypad library, set my Connect Pins in code and all buttons work. There is clearly something wrong with this code, I just don't know what.
Of course, I found the project ready, I edited only the most necessary things. Has anyone been able to help me with this problem? Thank you in advance for your help and please be understanding.
BombPro.ino
#include <Wire.h>
#include <Keypad.h>
//#include <LiquidCrystal.h>
//LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
#define BACKLIGHT_PIN 3
LiquidCrystal_I2C lcd(0x27,2, 1, 0, 4, 5, 6, 7);
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','a'},
{'4','5','6','b'},
{'7','8','9','c'},
{'*','0','#','d'}
//byte rowPins[ROWS] = {A4, A5, 13, 12};
//byte colPins[COLS] = {A0, A1, A2, A3};
byte rowPins[ROWS] = {A0, A1, A2, A3};
byte colPins[COLS] = {A4, A5, 13, 12};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char enteredText[8];
char password[8];
int key=-1;
char lastKey;
char var;
boolean passwordEnable=false;
char BT_RIGHT = '4';
char BT_UP = 'a';
char BT_DOWN = 'b';
char BT_LEFT = '6';
char BT_SEL = 'd';
char BT_CANCEL = 'c';
char BT_DEFUSER = 'x'; // not implemented
//leds
const int REDLED = 9;
const int GREENLED = 11;
boolean mosfetEnable = false;
const int mosfet = 9;
//IS VERY IMPORTANT THAT YOU TEST THIS TIME. BY DEFAULT IS IN 1 SEC. THAT IS NOT TOO MUCH. SO TEST IT!
const int MOSFET_TIME = 15000;
//TIME INTS
int GAMEHOURS = 0;
int GAMEMINUTES = 45;
int BOMBMINUTES = 4;
int ACTIVATESECONDS = 5;
boolean endGame = false;
boolean sdStatus = false; //search and destroy game enable used in config
boolean saStatus = false; //same but SAbotaghe
boolean doStatus = false; //for DEmolition
boolean start = true;
boolean defuseando;
boolean cancelando;
// SOUND TONES
boolean soundEnable = true;
int tonepin = 8;
int tonoPitido = 3000;
int tonoAlarma1 = 700;
int tonoAlarma2 = 2600;
int tonoActivada = 1330;
int errorTone = 100;
unsigned long iTime;
unsigned long timeCalcVar;
unsigned long redTime;
unsigned long greenTime;
unsigned long iZoneTime;
byte team=0;
void setup(){
lcd.begin(16, 2);
// lcd.init();
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
lcd.setBacklight(HIGH);
// lcd.backlight();
lcd.home();
lcd.setCursor(2,0);
lcd.print("NIEJESTEMPRO");
lcd.setCursor(3,1);
lcd.print(" AIRSOFT");
keypad.setHoldTime(50);
keypad.setDebounceTime(50);
keypad.addEventListener(keypadEvent);
delay(3000);
pinMode(GREENLED, OUTPUT);
pinMode(REDLED, OUTPUT);
pinMode(mosfet, OUTPUT);
byte bar1[8] = {
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
byte bar2[8] = {
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
byte bar3[8] = {
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
byte bar4[8] = {
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
byte bar5[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
byte up[8] = {
B00000,
B00100,
B01110,
B11111,
B11111,
B00000,
B00000,
byte down[8] = {
B00000,
B00000,
B11111,
B11111,
B01110,
B00100,
B00000,
lcd.createChar(0,bar1);
lcd.createChar(1,bar2);
lcd.createChar(2,bar3);
lcd.createChar(3,bar4);
lcd.createChar(4,bar5);
lcd.createChar(5,up);
lcd.createChar(6,down);
void loop(){
menuPrincipal();
void keypadEvent(KeypadEvent key){
switch (keypad.getState()){
case PRESSED:
switch (key){
case RELEASED:
switch (key){
case 'd': defuseando= false;
Serial.println("d Releases");
case 'c': cancelando=false;
Serial.println("c Releases");
case HOLD:
switch (key){
case 'd': defuseando= true;
Serial.println("d hold");
case 'c': cancelando=true;
Serial.println("c hold");
void disarmedSplash(){
endGame = false;
digitalWrite(REDLED, LOW);
digitalWrite(GREENLED, LOW);
if(sdStatus || saStatus){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("BOMBA DESARMADA");
lcd.setCursor(0,1);
lcd.print(" BUENOS GANAN");
delay(5000);
digitalWrite(GREENLED, HIGH);
//end code
lcd.clear();
lcd.print("Jugar otra vez?");
lcd.setCursor(0,1);
lcd.print("A: SI B: NO");
digitalWrite(REDLED, HIGH);
while(1)
var = keypad.waitForKey();
if(var == 'a' ){
tone(tonepin,2400,30);
if(sdStatus){
startGameCount();
search();
if(saStatus){
saStatus=true;
startGameCount();
start=true; //
sabotage();
if(var == 'b' ){
menuPrincipal();
void explodeSplash(){
cls();
delay(100);
endGame = false;
lcd.setCursor(1,0);
lcd.print("TERRORISTAS WIN");
lcd.setCursor(0,1);
lcd.print(" FIN DEL JUEGO");
for(int i = 200; i>0; i--)//
tone(tonepin,i);
delay(20);
noTone(tonepin);
if(mosfetEnable){
activateMosfet();
delay(5000);
cls();
//end code
lcd.setCursor(0,1);
while(1)
if(var == 'a' ){
if(sdStatus){
startGameCount();
search();
if(saStatus){
saStatus=true;
startGameCount();
start=true; //
sabotage();
if(var == 'b' ){
menuPrincipal();
domination.ino
void domination(){
//SETUP INITIAL TIME
int minutos = GAMEMINUTES-1;
boolean showGameTime=true;
unsigned long a;
unsigned long iTime=millis(); // initialTime in millisec
unsigned long aTime;
redTime=0;
greenTime=0;
int largoTono = 50;
// 0 = neutral, 1 = green team, 2 = red team
a=millis();
//Starting Game Code
while(1) // this is the important code, is a little messy but works good.
keypad.getKey();
aTime=millis()- iTime;
//Code for led blinking
timeCalcVar=(millis()- iTime)%1000;
if(timeCalcVar >= 0 && timeCalcVar <= 40)
if(team==1)digitalWrite(GREENLED, LOW);
if(team==2)digitalWrite(REDLED, LOW);
if(timeCalcVar >= 50 && timeCalcVar <= 100)
if(team==1)digitalWrite(GREENLED, HIGH);
if(team==2)digitalWrite(REDLED, HIGH);
// Sound!!! same as Destroy
if(timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable)tone(tonepin,tonoActivada,largoTono);
if(timeCalcVar >= 245 && timeCalcVar <= 255 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,tonoActivada,largoTono);
if(timeCalcVar >= 495 && timeCalcVar <= 510 && minutos-aTime/60000<4 && soundEnable)tone(tonepin,tonoActivada,largoTono);
if(timeCalcVar >= 745 && timeCalcVar <= 760 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,tonoActivada,largoTono);
//Help to count 3 secs
if(a+2000<millis()){
a=millis();
showGameTime=!showGameTime;
cls();
//THE NEXT TO METHODS SHOW "GAME TIME" AND "CONTROLED ZONE TIME" IT SHOWS 2 AND 2 SEC EACH
if(showGameTime){ //THE SECOND IS /2
lcd.setCursor(3,0);
lcd.print("GAME TIME");
lcd.setCursor(3,1);
printTime(minutos, aTime);
else if (!showGameTime){
lcd.setCursor(2,0);
if(team == 0)lcd.print("NEUTRAL ZONE");
if(team == 1)lcd.print(" GREEN ZONE");
if(team == 2)lcd.print(" RED ZONE");
if(team>0){
lcd.setCursor(3,1);
printTimeDom(millis()-iZoneTime,true);
//###########################CHECKINGS##################
//Check If Game End
if(minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0)
gameOver();
//Check If IS neutral
while((defuseando || cancelando) && team > 0)
cls();
if(team>0)lcd.print("NEUTRALIZING...");
lcd.setCursor(0,1);
unsigned int percent=0;
unsigned long xTime=millis(); //start disabling time
while(defuseando || cancelando)
keypad.getKey();
timeCalcVar = (millis()- xTime)%1000;
if( timeCalcVar >= 0 && timeCalcVar <= 20)
if(soundEnable)tone(tonepin,tonoAlarma1,200);
if(timeCalcVar >= 480 && timeCalcVar <= 500)
if(soundEnable)tone(tonepin,tonoAlarma2,200);
unsigned long seconds= millis() - xTime;
percent = (seconds)/(ACTIVATESECONDS*10);
drawPorcent(percent);
if(percent >= 100)
if(team==1){
greenTime+=millis()-iZoneTime;
iZoneTime=0;
if(team==2){
redTime+=millis()-iZoneTime;
iZoneTime=0;
team=0;
cls();
//Capturing red
while(defuseando && team == 0 )
cls();
if(team==0)lcd.print(" CAPTURING ZONE");
lcd.setCursor(0,1);
while(defuseando)
keypad.getKey();
if(percent >= 100)
team=2;
iZoneTime=millis();
cls();
//getting to green zone
while(cancelando && team == 0 )
cls();
lcd.setCursor(0,1);
while(cancelando)
keypad.getKey();
if(percent >= 100)
team=1;
iZoneTime=millis();
cls();
void gameOver(){
if(team==1)greenTime+=millis()-iZoneTime;
if(team==2)redTime+=millis()-iZoneTime;
while(!isPressed(BT_SEL)){
lcd.clear();
lcd.setCursor(3,0);
lcd.print("TIME OVER!");
lcd.setCursor(0,1);
//check who team win the base
if(greenTime>redTime){
//greenteam wins
lcd.print(" GREEN TEAM WIN ");
else{
//redteam wins
lcd.print(" RED TEAM WIN ");
delay(3000);
cls();
lcd.print("Red Time:");
lcd.setCursor(5,1);
printTimeDom(redTime,false);
delay(3000);
cls();
lcd.print("Green Time:");
lcd.setCursor(5,1);
printTimeDom(greenTime,false);
delay(3000);
lcd.print("Play Again?");
lcd.setCursor(0,1);
lcd.print("A : Yes B : No");
while(1)
if(var == 'a' ){
search();
if(var == 'b' ){
menuPrincipal();
keys.ino
//Used to get keys, here you can configure how works the input without modify the other code
boolean isPressed(char key)
Serial.print("checkeando= ");
Serial.print(key);
Serial.print(" estado = ");
Serial.print(keypad.getState());
Serial.print(keypad.getKey());
if(keypad.getKey() == key)
Serial.println(" TRUE");
return true;
else if(keypad.getKey() == key && keypad.getState() == 2)
Serial.print(" Hold!!");
Serial.println(key);
return true;
Serial.println(" Falso");
return false;
//This fuction compare enteredText[8] and password[8] variables
boolean comparePassword(){
for(int i=0;i<8;i++){
if(enteredText[i]!=password[i])return false;
return true;
//Set the password variable
void setCode(){
lcd.setCursor(0, 1);
while(1){
var= getNumber();
if(var !='x'){
enteredText[i] = var;
if (i != 0){
lcd.setCursor(i-1,1);
lcd.print("*");
lcd.print(var);
lcd.print(var);
void setPass(){
while(1){
var= getNumber();
if(var !='x'){
password[i] = var;
if (i != 0){
lcd.print("*");
lcd.print(var);
lcd.print(var);
void setNewPass(){
while(1){
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Enter New Pass");
setPass();
lcd.clear();
lcd.print("Retype Pass");
setCode();
if(comparePassword()){
lcd.clear();
lcd.print("Password Set OK!");
delay(2000);
else {
lcd.clear();
lcd.print("ERROR Dont Match!");
if(soundEnable)tone(tonepin,errorTone,200);
delay(2000);
//Whait until a button is pressed is is a number return the number 'char' if not return x
char getNumber(){
switch (var) {
case 'a':
return 'x';
case 'b':
return 'x';
case 'c':
return 'x';
case 'd':
return 'x';
case '*':
return 'x';
case '#':
return 'x';
default:
return var;
menu.ino
//##################MENUS###############################
void menuPrincipal(){ //MAIN MENU
//Draw menu
cls();//clear lcd and set cursor to 0,0
int i=0;
char* menu1[]={
"Search&Destroy","Sabotage","Domination", "Bomb Setup" }; // HERE YOU CAN ADD MORE ITEMS ON THE MAIN MENU
lcd.print(menu1[i]);
lcd.setCursor(15,1);
checkArrows(i,2);
while(1){
if(var == BT_UP && i>0){
i--;
cls();
checkArrows(i,3);
delay(100);
if(var == BT_DOWN && i<3){
i++;
cls();
checkArrows(i,3);
delay(100);
if(var == BT_SEL){
cls();
switch (i){
case 0:
sdStatus=true;
configQuickGame();
startGameCount();
search();
case 1:
saStatus=true;
configQuickGame();
startGameCount();
sabotage();
case 2:
doStatus=true;
configQuickGame();
startGameCount();
domination();
case 3:
config();
void config(){
//Draw menu
lcd.clear();
int i=0;
char* menu2[]={
"Game Config","OFF Time TEST", "RELE Test 3 sec.","...vacio..."}; // HERE YOU CAN ADD MORE ITEMS ON THE MENU
lcd.print(menu2[i]);
checkArrows(i,3);
while(1){
var=keypad.waitForKey();
i--;
lcd.clear();
checkArrows(i,3);
delay(50);
i++;
lcd.clear();
checkArrows(i,3);
delay(50);
if(var == BT_CANCEL){
menuPrincipal();
if(var == BT_SEL){
lcd.clear();
switch (i){
case 0:
//gameConfigMenu
lcd.print("No config menu!");
delay(2000);
config();
case 1:
//final time test menu
lcd.print("Final time sound");
digitalWrite(mosfet, HIGH);
delay(300);
digitalWrite(mosfet, LOW);
delay(300);
delay(300);
delay(200);
delay(100);
delay(200);
delay(100);
config();
case 2:
//test rele menu
cls();
lcd.print("RELE ON!");
digitalWrite(mosfet, HIGH); // turn the LED on (HIGH is the voltage level)
delay(3000); // wait for 3 second
cls();
lcd.print("RELE OFF!");
delay(2000);
config();
void configQuickGame(){
cls();
//GAME TIME
if(sdStatus || doStatus || saStatus){
lcd.print("Game Time:");
lcd.setCursor(0,1);
checkArrows(1,2);
delay(400);
while(1){
lcd.setCursor(0,1);
lcd.print(GAMEMINUTES);
lcd.print(" Minutos");
if(var == 'a' && GAMEMINUTES<180){
GAMEMINUTES++;
delay(50);
if(var == 'b' && GAMEMINUTES>1){
GAMEMINUTES--;
delay(50);
if(var == 'c') // Cancel or Back Button :')
menuPrincipal();
if(var == 'd') // Cancel or Back Button :')
cls();
//BOMB TIME
lcd.print("Bomb Time:");
lcd.setCursor(0,1);
checkArrows(1,2);
delay(400);
while(1){
lcd.setCursor(0,1);
lcd.print(BOMBMINUTES);
if(var == 'b' && BOMBMINUTES>1){
BOMBMINUTES--;
delay(50);
if(var == 'a' && BOMBMINUTES<20){
BOMBMINUTES++;
delay(50);
menuPrincipal();
cls();
//ARMING TIME
lcd.print("Arm time:");
lcd.setCursor(0,1);
checkArrows(1,2);
delay(400);
while(1){
lcd.setCursor(0,1);
lcd.print(ACTIVATESECONDS);
lcd.print(" segundos");
if(var == 'b' && ACTIVATESECONDS>5){
ACTIVATESECONDS--;
delay(50);
if(var == 'a' && ACTIVATESECONDS<30){
ACTIVATESECONDS++;
delay(50);
menuPrincipal();
ACTIVATESECONDS-=1; // Just a fix
//Want sound??
if(sdStatus || saStatus || doStatus){
cls();
lcd.print("Activar sonido?");
lcd.setCursor(0,1);
while(1)
if(var == 'a' ){
soundEnable=true;
if(var == 'b' ){
soundEnable=false;
//Activate Mosfet at Terrorist game ends??? Boom!
cls();
lcd.print("Activar RELE?");
lcd.setCursor(0,1);
while(1)
if(var == 'a' ){
mosfetEnable=true;
if(var == 'b' ){
mosfetEnable=false;
//You Want a password enable-disable game?
cls();
lcd.print("Activar CODIDO?");
lcd.setCursor(0,1);
while(1)
if(var == 'a' ){
setNewPass();
passwordEnable = true;
if(var == 'b' ){
passwordEnable = false;
//Continue the game :D
sabotage.ino
void sabotage(){
cls();
if(start){
start=false;
while(1){ // this is the important code, is a little messy but works good.
if(timeCalcVar >= 0 && timeCalcVar <= 50)
if(timeCalcVar >= 90 && timeCalcVar <= 130)
lcd.setCursor(3,0);
lcd.setCursor(3,1);
//PRINT TIME ON LCD
//Check If Game End
lcd.clear();
while(1){
lcd.print(" GAME OVER! ");
lcd.setCursor(0,1);
lcd.print(" DEFENDERS WIN ");
for(int i = 1000; i>200; i--){
if(soundEnable)tone(tonepin,i);
delay(5);
noTone(tonepin);
delay(5000);
cls();
menuPrincipal();
//USED IN PASSWORD GAME
if('d' == keypad.getKey() && passwordEnable){
lcd.clear();
lcd.setCursor(2,0);
lcd.print("ARMING BOMB");
delay(1000);//a little delay to think in the password
lcd.clear();
lcd.setCursor(3, 0);
lcd.print("Enter Code");
setCode();// we need to set the compare variable first
//then compare :D
destroySabotage();
lcd.clear();
lcd.setCursor(2,0);
lcd.print("Code Error!");
cls();
//Check If Is Activating
while(defuseando && !passwordEnable)
keypad.getKey();
cls();
lcd.clear();
lcd.setCursor(2,0);
lcd.setCursor(0,1);
while(defuseando)
keypad.getKey();
if( timeCalcVar >= 0 && timeCalcVar <= 40)
if(timeCalcVar >= 480 && timeCalcVar <= 520)
if(percent >= 100)
destroySabotage();// jump to the next gamemode
cls();
void destroySabotage(){
lcd.clear();
lcd.setCursor(3,0);
lcd.print("BOMB ARMED");
int minutos=BOMBMINUTES-1;
int largoTono = 50;
//MAIN LOOP
while(1){
//If you fail disarm.
if(endGame){
explodeSplash();
//Led Blink
if(soundEnable)tone(tonepin,tonoActivada,largoTono);
if(timeCalcVar >= 180 && timeCalcVar <= 220){
//Sound
aTime= millis()- iTime;
if( minutos-aTime/60000==0 && 59-((aTime/1000)%60) < 10)largoTono = 300;
lcd.setCursor(1,0);
lcd.print("DETONATION IN");
//Passed Time
lcd.setCursor(3,1);
////////HERE ARE THE TWO OPTIONS THAT ENDS THE GAME///////////
////TIME PASED AWAY AND THE BOMB EXPLODES
if(minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0)// Check if game ends
explodeSplash();
//print time
//// SECOND OPTION: YOU PRESS DISARMING BUTTON
//IF IS A PASSWORD GAME
cls();
lcd.print(" DISARMING BOMB");
lcd.clear();
lcd.setCursor(3,0);
//then compare :D
sabotage();
lcd.clear();
lcd.setCursor(2,0);
cls();
if(defuseando && !passwordEnable)// disarming bomb
lcd.clear();
lcd.setCursor(3,0);
lcd.print("DISARMING");
lcd.setCursor(0,1);
while(defuseando)
keypad.getKey();
//check if game time runs out during the disabling
if((minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0) || minutos-aTime/60000>4000000000){
endGame = true;
timeCalcVar=(millis()- xTime)%1000;
if(timeCalcVar>= 0 && timeCalcVar <= 20)
unsigned long seconds=(millis()- xTime);
percent= seconds/(ACTIVATESECONDS*10);
//BOMB DISARMED GAME OVER
if(percent >= 100)
sabotage();
cls();
searchdestroy.ino
void search(){
cls();
//var='o';
lcd.setCursor(0,0);
lcd.print("TIEMPO de JUEGO");
lcd.setCursor(3,1);
//PRINT TIME ON LCD
//Check If Game End
lcd.clear();
while(1){
lcd.print("FIN DEL TIEMPO!");
lcd.setCursor(0,1);
lcd.print("DEFENSORES WIN ");
delay(300);
delay(300);
delay(300);
delay(200);
delay(100);
delay(200);
delay(100);
delay(5);
noTone(tonepin);
delay(5000);
cls();
menuPrincipal();
//Serial.println(keypad.getKey());
lcd.clear();
lcd.print("ARMANDO BOMBA");
lcd.clear();
setCode();// we need to set the comparation variable first it writes on enteredText[]
//then compare :D
destroy();
lcd.clear();
lcd.setCursor(3,0);
cls();
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" ARMANDO BOMBA");
lcd.setCursor(0,1);
while(defuseando)
keypad.getKey();
if(percent >= 100)
destroy();// jump to the next gamemode
cls();
void destroy(){
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" BOMBA ARMADA");
int largoTono = 50;
//MAIN LOOP
while(1){
if(endGame){
explodeSplash();
//Led Blink
//Sound
lcd.setCursor(0,0);
lcd.print(" DETONACION EN ");
//Passed Time
lcd.setCursor(3,1);
explodeSplash();
//print time
lcd.clear();
lcd.setCursor(0,0);
lcd.print("DESARMANDO BOMBA");
lcd.clear();
lcd.setCursor(3,0);
//then compare :D
disarmedSplash();
lcd.clear();
lcd.setCursor(3,0);
cls();
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" DESARMANDO ");
lcd.setCursor(0,1);
while(defuseando)
keypad.getKey();
endGame = true;
if(percent >= 100)
disarmedSplash();
cls();
zutils.ino
void drawPorcent(byte porcent){
//TODO: Optimize this code
byte i=1;
int aDibujar=(8*porcent)/10;
lcd.setCursor(0,1);
if(aDibujar<5)
switch(aDibujar){
case 0:
case 1:
lcd.write((uint8_t)0);
case 2:
lcd.write(1);
case 3:
lcd.write(2);
case 4:
lcd.write(3);
while(aDibujar>=5){
if(aDibujar>=5)
lcd.write(4);
aDibujar-=5;
if(aDibujar<5)
switch(aDibujar){
case 0:
case 1:
case 2:
lcd.write(1);
case 3:
lcd.write(2);
case 4:
lcd.write(3);
void cls(){
lcd.clear();
lcd.setCursor(0,0);
void printTime(unsigned long minutos, unsigned long aTiempo){
//minutes
if((minutos-aTiempo/60000)<10)
lcd.print("0");
lcd.print(minutos-aTiempo/60000);
lcd.print(":");
//seconds
if((59-((aTiempo/1000)%60))<10)
lcd.print("0");
lcd.print(59-((aTiempo/1000)%60));
lcd.print(":");
//this not mach with real time, is just a effect, it says 999 because millis%1000 sometimes give 0 LOL
lcd.print(999-(millis()%1000));
void printTimeDom(unsigned long aTiempo, boolean showMillis){
//minutes
if((aTiempo/60000)<10)
lcd.print("0");
lcd.print(aTiempo/60000);
lcd.print(":");
//seconds
if(((aTiempo/1000)%60)<10)
lcd.print("0");
lcd.print((aTiempo/1000)%60);
if(showMillis){
lcd.print(":");
lcd.print(999-millis()%1000);
void startGameCount(){
cls();
lcd.setCursor(1,0);
lcd.print("Ready to Begin");
lcd.setCursor(0,1);
lcd.print(".Pulsa un Boton.");
keypad.waitForKey();//if you press a button game start
cls();
lcd.setCursor(1,0);
lcd.print("Starting Game");
for(int i = 5; i > 0 ; i--){ // START COUNT GAME INIT
lcd.setCursor(5,1);
tone(tonepin,2000,100);
lcd.print("IN ");
lcd.print(i);
cls();
void checkArrows(byte i,byte maxx ){
if(i==0){
lcd.write(6);
if(i==maxx){
lcd.setCursor(15,0);
lcd.write(5);
if(i>0 && i<maxx){
lcd.write(6);
lcd.write(5);
void activateMosfet(){
//lcd.print("Mosfet ON!");
delay(MOSFET_TIME); // wait for 4 second
//lcd.print("Mosfet OFF!");
