Problem with esp32 WIFI + UVM-30a sensor
Hello every one.
i test UVM sensor with code this is work .
value in UVM sensor can read to Serial monitor.
int analogApin = 15; // define OUT signal pin
int analogA; // define variable to store value read from pin
pinMode(analogApin, INPUT);
analogA = analogRead(analogApin); // read the voltage level on the A0
Serial.println((String)"UV level: " + analogA); // send the result to the serial monitor
delay(200); // pause for a moment before repeating
but if i write code WIFI to board esp32 , sensor just show 0 value only , no change value anything.
#include <WiFi.h>
#include <SPI.h>
char* ssid = "xxxxxxxxx";
char* password = "xxxxxxxx";
WiFi.begin(ssid , password);
Serial.println("Flux Workshop Example");
// set the OUT signal pin as an input
delay(500); // pause for a moment before repeating
what should i do , with problem this
thank you.
Do not use any pins on the GPIO portA for analog to digital conversions with an ESP32. The GPIO pins on portB are set up for analog to digital conversions use pins 33+.
Setting up an ESP32 for analog to digital conversions using the ESP32 API is not that difficult and gives a more stable output.
Include the ESP32 adc library.
#include <driver/adc.h>
in setup() initialize the analog to digital channel.
// set up A:D channels, refer: https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36
Using analog to digital converter 1 (the esp32 has 2).
adc1_config_width(ADC_WIDTH_12Bit); sets the analog to digital converter to 12 bits.
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11); set the analog converter on GPIO_NUM_36 to use the full range reference voltage of 3.3V.
adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading
is used to take an AD reading.
pinMode( (36 or 39, or 35, or 35, or 33) , INPUT); works as well and may be easier.
Idahowalker:
Idahowalker:
thank you very much , i will do as your suggest me today this.
