problem with ethernet library since updating to 022
hi im having problems with the ethernet library since the last arduino update.
everything compiles and therese no error messages but i cant connect to the ethernet shield. when im trying to ping it it says host is down no connection.
im using arduino duemilanove with atmega 328 and a ethernet shield with a wiznet 5100 chip on it.
and the latest version of the developing environment. (0022)
is there anyone that has a solution or have the sam problem as me.
What version did you upgrade from? I don't think the change to the IDE makes any difference. Why did you upload new code to the functioning Arduino?
i upgraded from 0021.
mabye its not the upgrade thats the problem.
i was about to start a new project it didnt work so i loaded the web client example to the arduino and added
#include <SPI.h>
to the example and change the ip to the one i wanted to use
(192.168.2.6)
to se if it was something wrong with code i had written or something elese.
it did not work with the web client example either.
next I tried the web server example it did not work.
i cheked the status led on the shield and every thing looks ok.
the rx and tx leds flash sometimes.
next i tried another shield but with the same result.
then i tried another arduino board but it did not work either.
now im suspecting that it is something wrong with either the library or the ide.
i have used the ethernet library before with sucess but i cant rember wich version i have used.
