Problem with ethernet response
Using the program:
#include <ArduinoJson.h>
#include <Ethernet.h>
#include <SPI.h>
delay(4000);
// Initialize Serial port
while (!Serial) continue;
// Initialize Ethernet library
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
Ethernet.init(8); // use pin 53 for Ethernet CS
if (!Ethernet.begin(mac)) {
Serial.println(F("Failed to configure Ethernet"));
return;
delay(4000);
Serial.println(F("Connecting..."));
// Connect to HTTP server
EthernetClient client;
client.setTimeout(10000);
if (!client.connect("arduinojson.org", 80)) {
Serial.println(F("Connection failed"));
return;
Serial.println(F("Connected!"));
// Send HTTP request
client.println(F("GET /example.json HTTP/1.0"));
client.println(F("Host: arduinojson.org"));
client.println(F("Connection: close"));
if (client.println() == 0) {
Serial.println(F("Failed to send request"));
return;
// Check HTTP status
char status[32] = {0};
client.readBytesUntil('\r', status, sizeof(status));
if (strcmp(status, "HTTP/1.1 200 OK") != 0) {
Serial.print(F("Unexpected response: "));
Serial.println(status);
return;
// Skip HTTP headers
char endOfHeaders[] = "\r\n\r\n";
if (!client.find(endOfHeaders)) {
Serial.println(F("Invalid response"));
return;
// Allocate JsonBuffer
// Use Redirecting… to compute the capacity.
const size_t capacity = JSON_OBJECT_SIZE(3) + JSON_ARRAY_SIZE(2) + 60;
DynamicJsonBuffer jsonBuffer(capacity);
// Parse JSON object
JsonObject& root = jsonBuffer.parseObject(client);
if (!root.success()) {
Serial.println(F("Parsing failed!"));
return;
// Extract values
Serial.println(F("Response:"));
Serial.println(root["sensor"].as<char*>());
Serial.println(root["time"].as<char*>());
Serial.println(root["data"][0].as<char*>());
Serial.println(root["data"][1].as<char*>());
// Disconnect
client.stop();
// not used in this example
I should get a nice JSON response but instead of them, I'm getting something as you can see in screenshot. Could you please help me where is the problem?
No. You failed to attach the promised screenshot (is a screenshot necessary? Wouldn't posting the text output be the better alternative?). You failed to put code tags around your code. Fix this.
