hii i am making a project with arduino in which when we press a button on a webserver ,led lights up.i have been able to successfully set up a webserver but whenever i press the button nothing happens,as soon as i upload a sketch led lights up and remain in that position .please help me to sort this out,below are sketches i uploaded to arduino
Sketch 1:
include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 177 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
pinMode(11, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println("Home Automation");
client.println("");
client.println("");
client.println("
Home Automation
");client.println("
client.println("
client.println("<a href="/?lighton"">Turn On Light");
client.println("<a href="/?lightoff"">Turn Off Light
client.println("");
client.println("");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("?lighton") >0)//checks for on
digitalWrite(11, HIGH); // set pin 4 high
Serial.println("Led On");
else{
if(readString.indexOf("?lightoff") >0)//checks for off
digitalWrite(11, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
i copied it from instructables,can anybody tell me why it is not working ![]()
