Problem with extern variables
Hello,
I have a problem with my sketch using 'extern'.
In the main file:
const byte someVariable[10] PROGMEM = {0,1,2,3,4,5,6,7,8,9};
setup ()
and in a different tab/file I try to add an extern statement, something like:
extern const byte someVariable[10] PROGMEM;
void someFunction(void)
  // Example code just to show where I use this.
  someVariable[0] = 4;
But I get an error when trying to compile the sketch. I have search for a solution, but have not found anything that have helped me solve this problem.
The error I get is
sketch/someFunction.cpp:100: undefined reference to `someVariable'
Suggestions?
Not really your question on external, but How do you think the compiler can assign a value to something that is const and in flash memory when you write:
Sorry for that mistake, forget that statement. I wrote the message in a hurry. It should be:
  if (someVariable[0] == 4) {... }
The real code only read the variable. The problem with compiling and linking remain.
Tabs aren't external. The IDE combines all the files represented by tabs into a single sketch. Globals defined in the main (first) tab are in scope for all other tabs.
The data is in PROGMEM; you can’t read it like that.
Keyword const objects have internal linkage in C++, i.e. they are not visible outside of the compilation unit they are declared in.
ToddL1962:
This works.
.ino file:
extern const uint8_t arraySize;
extern const uint8_t someVariable[];
const uint8_t arraySize = 10;
const uint8_t someVariable[arraySize] PROGMEM = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9};
void printIt();
  Serial.println("From setup():");
  for (uint8_t i = 0; i < arraySize; i++) {
    uint8_t b = pgm_read_byte(someVariable + i);
    Serial.println(b);
  printIt();
OtherFile.cpp:
#include <Arduino.h>
void printIt() {
  Serial.println("From printIt():");
    Serial.println(b);
Output:
From setup():
0
1
2
3
4
5
6
7
8
9
From printIt():
0
1
2
3
4
5
6
7
8
9
Thanks a lot gfvalvo - it worked!
SteveMann: Tabs aren't external. The IDE combines all the files represented by tabs into a single sketch. Globals defined in the main (first) tab are in scope for all other tabs.
You're talking about using the Arduino-recommended practice of multiple .ino files / tabs. IMO, that's useless. If you use you proper .cpp and .h files / tabs then you can have meaningful code modularity.
TheMemberFormerlyKnownAsAWOL: The data is in PROGMEM; you can't read it like that.
If it is in PROGMEM, how should it be (read)?
Since the arrays are rather small, I have dropped the PROGMEM, but it would be nice to know how this can be done if I have larger arrays I want/must have in PROGMEM.
thehardwareman:
The way @gfvalvo did it.
Check the PROGMEM reference page.
ToddL1962: Keyword const objects have internal linkage in C++, i.e. they are not visible outside of the compilation unit they are declared in.
You probably meant "static".
TheMemberFormerlyKnownAsAWOL: The way @gfvalvo did it. Check the PROGMEM reference page.
Of cause... did not see that his example used PROGMEM. Silly me... Thanks for all replies.
