Hello there, I have a simple project to create a security system with internet, for security device I use fingerprint sensor (ZFM60), esp8266-01 as internet connection provider and send data to iot web cloud, and arduino uno as microcontroller.
And I have a problem about sending fingerprint sensor data via esp8266-01 to the iot web cloud, the data always fails to be sent. Help me to know where the problem is
there the code:
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#define SSID "5NY"
#define PASS "masukaja890"
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
SoftwareSerial esp8266(12,13);
char *apiKey ="80594f339bbaff6afb045334f1faa5da";
void setup()Â
Â
 esp8266.begin(115200);Â
 Serial.println("Test ESP");
 setupesp8266();
 connectwifi();
Â
 finger.begin(57600);
Â
 if (finger.verifyPassword())
  Serial.println("Found fingerprint sensor!");
  Serial.println("Did not find fingerprint sensor :(");
  while (1);
 Serial.println("Waiting for valid finger...");
 int getFingerprintIDez();
 uint8_t p = finger.getImage();
 if (p != FINGERPRINT_OK) return -1;
 p = finger.image2Tz();
 p = finger.fingerFastSearch();
Â
 if(finger.fingerID==2)                                    //my number ID is 2
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" as Yunus ");
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
 Â
  Serial.println("Sending data");
 Â
  int user;
  user = finger.fingerID;
  senddata("No", user);
void senddata(String ID,int No)
 String cmd = "AT+CIPSTART=\"TCP\",\"";
 cmd += "geeknesia.com";
 cmd += "\",80";
 esp8266.println(cmd);
 delay(2000);
 cmd="";
 if(esp8266.find("Error"))
  Serial.println("AT+CIPSTART Error");
  return;
  Serial.println("AT+CIPSTART Success");
Â
 String getStr = "GET /api/data?api_key=";
 getStr += apiKey;
 getStr += "&attributes={\"";
 getStr += ID;
 getStr += "\":\"";
 getStr += No;
 getStr +="\"}"; Â
 getStr += "\r\n\r\n";Â
 cmd = "AT+CIPSEND=";
 cmd += String(getStr.length());
 Serial.println(getStr.length());
 Serial.println(getStr);
 delay(100);
 if(esp8266.find(">"))
  esp8266.print(getStr);
  Serial.print("Data Sent");
  esp8266.println("AT+CIPCLOSE");
  Serial.print("Data Error");
 cmd="";
void setupesp8266()
 esp8266.println("AT+RST");
 delay(3000);
 esp8266.println("AT");
 if (esp8266.find("OK"))
 Serial.println("ESP Okey");}
 Serial.println("ESP Failed");}
void connectwifi()
 esp8266.println("AT+CWMODE=3");
 delay(2000);
 String cmd = "AT+CWJAP=\"";
 cmd+=SSID;
 cmd+="\",\"";
 cmd+=PASS;
 cmd+="\"";
 delay(5000);
 cmd="";
 {Serial.println("Connect to internet");}
 {Serial.println("Failed to connect internet");}
and this in serial monitor
Test ESP
ESP Okey
Connect to internet
Found ID #2 as Yunus with confidence of 108
Sending data
AT+CIPSTART Success
80
GET /api/data?api_key=80594f339bbaff6afb045334f1faa5da&attributes={"No":"2"}
Data Error
And I've tried to send random data using only esp8266-01, and it works that proves that my esp8266-01 is not broken, there the code:
#define SSID "5NY"
 delay(2000);Â
 setupesp8266();
 connectwifi();
Â
 int data2;             //this random data
 data2 = 2;
 senddata ("No", data2);
Â
void setupesp8266()
 delay(3000);
void connectwifi()
 delay(2000);
 cmd+=SSID;
 cmd+="\",\"";
 cmd+=PASS;
 cmd+="\"";
 delay(5000);
 cmd="";
void senddata(String ID,int No)Â // fungsi untuk send data
 cmd += "\",80";
 delay(2000);
 cmd="";
 {Serial.println("AT+CIPSTART Error");
 return;}
 {Serial.println("AT+CIPSTART Success");}
Â
 getStr += apiKey;
 getStr += ID;
 getStr += "\":\"";
 getStr += No;
 getStr +="\"}"; Â
 cmd="";
and in serial monitor:
Test ESP
ESP Okey
Connect to internet
AT+CIPSTART Success
80
Data Sent
