Problem with " for loop()" (resolved)
Hello, I’m new to Arduino. I have the following problem with for loop()
The LED does not stop, I need to know because it does not stop at ARDUINO, and if MINIBLOQ
Arduino ; print “0,1,2,3,4,0,1,2,3 …” no stop led
int _i;
pinMode( 13 , OUTPUT);
for (_i=0; _i< ( 5 ); ++_i )
digitalWrite( 13 , HIGH );
delay( 200 );
digitalWrite( 13 , LOW );
delay( 200 );
Serial.print( _i );
Serial.println("");
Arduino + Ardublock ; but does not stop printing
int _ABVAR_1_;
for (_ABVAR_1_=0; _ABVAR_1_< ( 5 ); ++_ABVAR_1_ )
delay( 200 );
delay( 200 );
Serial.print( _ABVAR_1_ ); print  5,5,5,5,5......
Serial.println("");
Minibloq ; stops but does not print text
#include "stdlib.h"
#include "IRremote.h"
#include "pitches.h"
#include "Minibloq.h"
	initBoard();
	for(unsigned int _i=0; _i<(unsigned int)(5); _i++)
		DigitalWrite(D13_LED,
		delay(100);
		delay(100);
Modkit ; Modkit, stops, I have the Alpha account, I can not see the code and print text
Thanks
Your first problem is not with the for loop but with the function "loop ()", which....loops.
If you just want one cycle of the for loop, put it in setup() and leave loop() blank.
Second problem doesn't even compile (I didn't even try), so I don't know why you say it doesn't print anything.
What's that?
I can't even begin to guess what that means.
What I need is to blink (x) amount and stop.
Minibloq works but I can not put Serial.print texts
In MINIBLOQ I must be wrong
I will try from Arduino, your suggestion
Thanks
PD: DigitalWrite(D13_LED) is a compilation with minibloq http://blog.minibloq.org/
AWOL:
What's that?
Modkit http://blog.minibloq.org/ http://blog.ardublock.com/
I'm trying, I would like to do with Arduino MAIN but I get no :smiley:
Thanks
I'm sorry, I don't know what you mean by "Arduino MAIN ".
I've never used a graphical environment for the Arduino - does it have its own forum?
I'm guessing that English is not your native language - is there someone who can help you in the International section?
Thanks, solved XD with ARDUINO 1.0 .
int pinLED = 13;
	for(unsigned int _i=0; _i<(unsigned int)(10); _i++)
	digitalWrite(13, HIGH);
	digitalWrite(13, LOW);
        Serial.println(_i);
const int pinLED = 13;
  pinMode( pinLED, OUTPUT);
  for(int i=0; i < 10; i++) {
    digitalWrite(pinLED, HIGH);
    digitalWrite(pinLED, LOW);
    Serial.println(i);
Thanks :wink:
I only want to add this that it's possible to print in Minibloq with the Serial block. But in the current version, it will only print numbers, not text. That may be enough for this example, but will not be able to print the automatic generated variable for the repeat block (called "_i") so you will need to add a second variable as counter to print it.
Regarding the question about the Minibloq forum, it's here:
minibloq.net/forum
Cheers,
Julián
Hi, If you're interested in following the development of ArduBlock, mentioned above, there is now a discussion group here:
http://groups.google.com/group/ardublock?hl=en
