Problem with GET response
Hi, I’m having some problems with the response from a GET operation.
The problem is that when I read the console, the GET is sort of preformed twice. The first time it’s ok. But the second time the values are gone.
The console response:
first time the client connects → site requesting the values
the second time → site posting values
I think the site is requesting values, then posting new one’s and then requesting them again. Is there a way I can “remember” the item & value from the post?
server is at 192.168.1.177
GET /verlichting HTTP/1.0
Test =0
Request= lights
Item=
Value =
Test =0
Request= lights
Item=
Value =
{room1="0"}{room2="0"}{room3="0"}{room4="0"}
client disonnected
GET /lights/?values=/{room1="0"}{room2="0"}{room3="0"}{room4="0"} HTTP/1.0
Test =1
Request= lights
Item= ?values=
Value = {room1="0"}{room2="0"}{room3="0"}{room4="0"}
Test =0
Request= lights
Item=
Value =
client disonnected
GET /lights HTTP/1.0
Request= lights
Item=
Value =
Request= lights
Item=
Value =
client disonnected
The code:
while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if(c != '\n' && c != '\r' && index < 255){ // Reads until either an eol character is reached or the buffer is full
          clientline[index++] = c;
          continue;
        String urlString = String(clientline);
        //  extract the operation
        String op = urlString.substring(0,urlString.indexOf(' '));
        //  we're only interested in the first part...
        urlString = urlString.substring(urlString.indexOf('/'), urlString.indexOf(' ', urlString.indexOf('/')));
        urlString.toCharArray(clientline, 255);
        char *i;
        char *request = strtok_r(clientline,"/", &i);
        char *item = strtok_r(NULL, "/", &i);
        char *value = strtok_r(NULL, "/", &i);
        Serial.print("Request= "); Serial.println(request);
        Serial.print("Item= "); Serial.println(item);
        Serial.print("Value = "); Serial.println(value);
// if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // add a meta refresh tag, so the browser pulls again every 5 seconds:
          //client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          String restBegin = "{";
          String restEnd = "\"}";
          String restResponse = String();
          if (strcmp(request, "heating")==0){
            client.println("
            String restHeating = "recived heating request";
            restResponse = restBegin + restHeating + restEnd;
            Serial.println(restResponse);
            client.println(restResponse);
            client.println("
            client.println("</html>");
          if (strcmp(request, "lights")==0){
            if (strcmp(item, NULL)==0){
            client.println("
           // Building a REST response
            String restRoom1 = "room1=\""; String restRoom2 = "room2=\"";
            String restRoom3 = "room3=\""; String restRoom4 = "room4=\"";
            restResponse = restBegin + restRoom1 + room1[4] + restEnd;
            restResponse += restBegin + restRoom2 + room2[4] + restEnd;
            restResponse += restBegin + restRoom3 + room3[4] + restEnd;
            restResponse += restBegin + restRoom4 + room[4] + restEnd;
            client.println("
            if (strcmp(item, "?values=")){
              Serial.print("Values entering console: "); Serial.println(value);
          else {
            client.println();
        if (c == '\n') {
          // you're starting a new line
          currentLineIsBlank = true;
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
