#define TdsSensorPin A1
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0;
int copyIndex = 0;
float averageVoltage = 0;
float tdsValue = 0;
float temperature = 16; // current temperature for compensation
float calibration_value = 21.34;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10],temp;
int sensorPin = A2;
float volt;
float ntu;
pinMode(TdsSensorPin,INPUT);
tds();
ph();
tur();
void ph() {
for(int i=0;i<10;i++)
buffer_arr[i]=analogRead(A0);
delay(30);
for(int i=0;i<9;i++)
for(int j=i+1;j<10;j++)
if(buffer_arr[i]>buffer_arr[j])
temp=buffer_arr[i];
buffer_arr[i]=buffer_arr[j];
buffer_arr[j]=temp;
avgval=0;
for(int i=2;i<8;i++)
avgval+=buffer_arr[i];
float volt=(float)avgval*5.0/1024/6;
float ph_act = -5.70 * volt + calibration_value;
Serial.println(ph_act);
// median filtering algorithm
int getMedianNum(int bArray[], int iFilterLen){
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++) {
for (i = 0; i < iFilterLen - j - 1; i++) {
if (bTab[i] > bTab[i + 1]) {
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0){
bTemp = bTab[(iFilterLen - 1) / 2];
else {
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
void tds()
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U){ //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if(analogBufferIndex == SCOUNT){
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 800U){
for(copyIndex=0; copyIndex<SCOUNT; copyIndex++){
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
// read the analog value more stable by the median filtering algorithm, and convert to voltage value
averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0;
//temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationCoefficient = 1.0+0.02*(temperature-25.0);
float compensationVoltage=averageVoltage/compensationCoefficient;
//convert voltage value to tds value
tdsValue=(133.42*compensationVoltage*compensationVoltage*compensationVoltage - 255.86*compensationVoltage*compensationVoltage + 857.39*compensationVoltage)*0.5;
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
Serial.print("TDS Value:");
Serial.print(tdsValue,0);
Serial.println("ppm");
delay(10);
void tur()
volt = 0;
for(int i=0; i<800; i++)
volt += ((float)analogRead(sensorPin)/1023)*5;
volt = volt/800;
volt = round_to_dp(volt,2);
if(volt < 2.5){
ntu = 3000;
}else{
ntu = -1120.4*square(volt)+5742.3*volt-4353.8;
Serial.println(ntu);
float round_to_dp( float in_value, int decimal_place )
float multiplier = powf( 10.0f, decimal_place );
in_value = roundf( in_value * multiplier ) / multiplier;
return in_value;
Good day to all my friends here, i am a newbie to arduino trying to get the value from analog pH sensor, turbidity sensor and tds sensor. The code above i tried was able to get the input from sensors, but the output is rather abit peculiar. I tested my sensors with only water (should be pH7, 0-5NTU and small value of tds). I have tried calibrating each of them and tested them with their own code individually, everything worked just fine until I put all the individual codes together. The output from serial monitor went unstable. The NTU was supposed to be within 5 now has exceed 170+, pH has lowered from 6-7 to 3-4 and the tds is not working finely (the value is 0 when it is not in contact with water and it stayed at 75ppm). So, im thinking that maybe something is wrong with my code arrangement but i have no clue on what is wrong. Could someone help me out?
