@per1234
Last 2 days I encountered serious problems with GitHub - Arduino-CI/arduino_ci: Unit testing and Continuous Integration (CI) for Arduino libraries, from a Ruby gem test runner I use for my libraries.
unit tests got struck in an endless loop, giving no output or partial output. Underlying event is an AddressSanitizer:DEADLYSIGNAL, which makes the VM / workflow notorious hard to cancel.
Root cause seems to be connected to the ubuntu-latest which is updated recently, so not to the Arduino-CI itself. So people using other GitHub workflows may encounter the same problem.
The problem is described in more detail - Crashing Clang with Asan+Ubsan builds in 20240310.1.0 Ubuntu 22.04. · Issue #9491 · actions/runner-images · GitHub
This link also provides a patch / workaround. sudo sysctl vm.mmap_rnd_bits=28
I also added an explicit time-out to the workflow yaml file so the workflow /VM does not stay dangling for 6 hours (default GitHub timeout).
on: [push, pull_request]
jobs:
runTest:
runs-on: ubuntu-latest
timeout-minutes: 20
steps:
- uses: actions/checkout@v4
- uses: ruby/setup-ruby@v1
with:
ruby-version: 2.6
- run: |
gem install arduino_ci
arduino_ci.rb
