Problem with GPIO 5 (D1) output mode high or low
I'm trying to get a relay to function to turn on and off power to a stepper motor to open a vent. I believe I'm using the correct code however when I print the state of the pin it always returns the pin number. I have other pins that are working correctly so I'm confused on what the issue is.
I'm using
const int relayPin = 5;
digitalWrite (relayPin, HIGH);
the full code below....
#include "DHTesp.h"
#include <Stepper.h>
#define STEPS 200
Stepper stepper(STEPS, 15, 13);
#define motorInterfaceType 1
// defines pins numbers
const int LimitSwitch_Open_Pin = 2;
const int LimitSwitch_Closed_Pin = 14;
DHTesp dht;
stepper.setSpeed(500); // Sets stepper speed
dht.setup(0, DHTesp::DHT11); // Connect DHT sensor to GPIO 0
// Sets pinModes
pinMode(LimitSwitch_Open_Pin , INPUT);
pinMode(LimitSwitch_Closed_Pin , INPUT);
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH);
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity();
float temperature = dht.getTemperature();
Serial.println("Temperature");
Serial.println(temperature);
Serial.println(humidity);
float openSw = digitalRead( LimitSwitch_Open_Pin);
float closedSw = digitalRead( LimitSwitch_Closed_Pin);
Serial.print("Closed endsop State=");
Serial.println(closedSw);
Serial.print("Open endstop State=");
Serial.println(openSw);
Serial.print("RelayPin State=");
Serial.println(relayPin);
if (temperature >= 22 && openSw == HIGH) {
digitalWrite(relayPin, LOW);
delay(200);
ventOpen();
else {
if (temperature <= 21 && closedSw == HIGH) {
delay(200);
ventClose();
void ventOpen() {
float openSw = digitalRead(LimitSwitch_Open_Pin);
while(digitalRead(LimitSwitch_Open_Pin) == HIGH) {
stepper.step(-10);
yield();
Serial.println("Vent Open!");
void ventClose() {
float openSw = digitalRead(LimitSwitch_Closed_Pin);
while(digitalRead(LimitSwitch_Closed_Pin) == HIGH) {
stepper.step(10);
yield();
Serial.println("Vent Closed!");
Compare and contrast:
Using a float to store the state is a bit odd though.
If you are talking about the statement
it prints really the pin number. If you will see the pin state you must get the state and print it.
**Serial.println(digitalRead(relayPin)); **
I have it working now thanks to the forum and switched "float" to "byte"
thanks to all!
