problem with gps + arduino Uno
I’ve got problem with reading data from gps. I wrote a simple program:
#include <SoftwareSerial.h>
int rxPin = 2;
int txPin = 3;
SoftwareSerial gpsSerial =  SoftwareSerial(rxPin, txPin);
 pinMode(rxPin, INPUT);
 pinMode(txPin, OUTPUT);
 gpsSerial.begin(38400);
 char c;
 while (gpsSerial.available())
   c = gpsSerial.read();
   Serial.println(c);
but I only get trash, does anybody know why?
Because you have a speed mismatch? Because you have no inversion on your level converters? Because you've not given us enough to go on.
GPS Venus 3.3 http://www.sparkfun.com/products/9171 Ok, I changed the speed. What do you mean with:
Because you didn't tell us what GPS unit you were using, I assumed it had RS232 levels, but now you've told us the one you're using, I can see that you don't need level conversion and inversion.
Which probably leaves speed mismatch. What is the default line speed for the device?
It's 9600
Module outputs the standard NMEA-0183 or SkyTraq Binary sentences at a default rate of 9600bps (adjustable to 115200bps).
Which is not, of course, compatible with:
The GPS is not a MIDI device, so why are you trying to talk to it like it is?
I've changed already this line on:
gpsSerial.begin(9600);
Is it possible to receive correct data using this short program?
So why are you talking to it at 38.4k?
Certainly should be. But, you have not provided any proof that you are not getting correct data.
38.4k??
Yes!
I get this:
I get this:
Now, provide some proof that the Arduino is talking to the serial monitor correctly. Put a Serial.print() statement in setup(), and make sure that that statement results in valid output on the serial monitor.
i did it and i get “ok” on serial monitor plus some characters
 Serial.print("ok");
Serial.println(c, HEX);
I use
and I get
ok 78 FFFFFFFE 0 FFFFFFE0 FFFFFF80 78 0 0 FFFFFF80 FFFFFF80 FFFFFFF8 FFFFFF80 78
how convert or read it to NMEA data? I assumed that there are correct data
