system
May 22, 2012, 10:11am
1
I've got problem with reading data from gps. I wrote a simple program:
#include <SoftwareSerial.h>
int rxPin = 2;
int txPin = 3;
SoftwareSerial gpsSerial = SoftwareSerial(rxPin, txPin);
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
gpsSerial.begin(38400);
char c;
while (gpsSerial.available())
c = gpsSerial.read();
Serial.println(c);
but I only get trash, does anybody know why?
system
May 22, 2012, 10:13am
2
Because you have a speed mismatch?
Because you have no inversion on your level converters?
Because you've not given us enough to go on.
system
May 22, 2012, 10:22am
3
GPS Venus 3.3
Ok, I changed the speed.
What do you mean with:
system
May 22, 2012, 10:24am
4
Because you didn't tell us what GPS unit you were using, I assumed it had RS232 levels, but now you've told us the one you're using, I can see that you don't need level conversion and inversion.
Which probably leaves speed mismatch.
What is the default line speed for the device?
system
May 22, 2012, 10:29am
6
Module outputs the standard NMEA-0183 or SkyTraq Binary sentences at a default rate of 9600bps (adjustable to 115200bps).
Which is not, of course, compatible with:
The GPS is not a MIDI device, so why are you trying to talk to it like it is?
system
May 22, 2012, 10:33am
7
I've changed already this line on:
gpsSerial.begin(9600);
Is it possible to receive correct data using this short program?
system
May 22, 2012, 10:34am
8
So why are you talking to it at 38.4k?
system
May 22, 2012, 10:36am
9
Certainly should be. But, you have not provided any proof that you are not getting correct data.
system
May 22, 2012, 10:43am
13
I get this:
Now, provide some proof that the Arduino is talking to the serial monitor correctly. Put a Serial.print() statement in setup(), and make sure that that statement results in valid output on the serial monitor.
system
May 22, 2012, 10:47am
14
i did it and i get "ok" on serial monitor plus some characters
Serial.print("ok");
system
May 22, 2012, 11:05am
16
I use
Serial.println(c, HEX);
and I get
ok
78
FFFFFFFE
FFFFFFE0
FFFFFF80
78
FFFFFF80
FFFFFF80
FFFFFFF8
FFFFFF80
78
how convert or read it to NMEA data? I assumed that there are correct data
