Hey,
I've tried to use GPS module and microSD card module together. When I use it separately, everything works fine - GPS prints NMEA protocol to serial monitor and sample text is saving to microSD card. The problem is when I try to connect it.
GPS is connect to RX and TX, microSD card module use 4 pins: MOSI - pin 11, MISO - pin 12. CLK - pin 13, CS - pin 4.
I use SD.h, SPI.h and SoftwareSerial.h.
When I run the serial monitor, both modules initiate their work and everything STOPS.
What should be wrong? Any ideas?
Cheers!
