Problem with GPS(ZED-F9P) and SD card
I'm pretty new to Arduino.
I want to save the data from GPS to SD card but it's seems to conflict between GPS and SD card .
They can't work at the same time .
Anyone have any ideas?
sparkfun BlackBoard(uno) to SD card
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - pin 10 depends on your SD card shield or module.
BlackBoard to GPS
I use Qwiic to connect BlackBoard and GPS
GPS (ZED-F9P)→I2C
SD card → SPI
Here is the code :
  Reading lat and long via UBX binary commands - no more NMEA parsing!
  By: Nathan Seidle
  SparkFun Electronics
  Date: January 3rd, 2019
  License: MIT. See license file for more information but you can
  basically do whatever you want with this code.
  This example shows how to query a Ublox module for its lat/long/altitude. We also
  turn off the NMEA output on the I2C port. This decreases the amount of I2C traffic
  dramatically.
  Note: Long/lat are large numbers because they are * 10^7. To convert lat/long
  to something google maps understands simply divide the numbers by 10,000,000. We
  do this so that we don't have to use floating point numbers.
  Leave NMEA parsing behind. Now you can simply ask the module for the datums you want!
  Feel like supporting open source hardware?
  Buy a board from SparkFun!
  ZED-F9P RTK2: https://www.sparkfun.com/products/15136
  NEO-M8P RTK: https://www.sparkfun.com/products/15005
  SAM-M8Q: https://www.sparkfun.com/products/15106
  Hardware Connections:
  Plug a Qwiic cable into the GPS and a BlackBoard
  If you don't have a platform with a Qwiic connection use the SparkFun Qwiic Breadboard Jumper (https://www.sparkfun.com/products/14425)
  Open the serial monitor at 115200 baud to see the output
#include <Wire.h> //Needed for I2C to GPS
#include <SPI.h>
#include <SD.h>
#include "SparkFun_Ublox_Arduino_Library.h" //http://librarymanager/All#SparkFun_Ublox_GPS
SFE_UBLOX_GPS myGPS;
File myFile;
long lastTime = 0; //Simple local timer. Limits amount if I2C traffic to Ublox module.
void saveSD();
  while (!Serial); //Wait for user to open terminal
  Serial.println("SparkFun Ublox Example");
  Wire.begin();
  if (myGPS.begin() == false) //Connect to the Ublox module using Wire port
    Serial.println(F("Ublox GPS not detected at default I2C address. Please check wiring. Freezing."));
    while (1);
    Serial.println("GPS.Success.");
  myGPS.setI2COutput(COM_TYPE_UBX); //Set the I2C port to output UBX only (turn off NMEA noise)
  myGPS.saveConfiguration(); //Save the current settings to flash and BBR
    while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("failed!");
    while (1);
  Serial.println("SD.Success.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  //Query module only every second. Doing it more often will just cause I2C traffic.
  //The module only responds when a new position is available
  if (millis() - lastTime > 1000)
    lastTime = millis(); //Update the timer
    long latitude = myGPS.getLatitude();
    Serial.print(F("Lat: "));
    Serial.print(latitude);
    long longitude = myGPS.getLongitude();
    Serial.print(F(" Long: "));
    Serial.print(longitude);
    Serial.print(F(" (degrees * 10^-7)"));
    long altitude = myGPS.getAltitude();
    Serial.print(F(" Alt: "));
    Serial.print(altitude);
    Serial.print(F(" (mm)"));
    byte SIV = myGPS.getSIV();
    Serial.print(F(" SIV: "));
    Serial.print(SIV);
    saveSD();
void saveSD()
    myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.println("Writing to test.txt...");
    myFile.println(myGPS.getLatitude());
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
Serial Monitor:
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
OK! I have already modify it.
Thanks for updating your post @Keddie_. We still need to know about your circuit, as TomGeorge requested.
