Problem with heater control
I have a Uno card. I am trying to build a heater control to replace and older discontinued unit.
I need to test flame sensor, if sensor reads flame do nothing.
If it read no flame count 8 seconds, turn on spark and fuel for 5 seconds. If flame is detected I turn on second fuel nozzle.
If at any time no flame is detected shut of ardino without restart.
I cannot get the program to look at sensor and shut off.
I understand not using go to but it appears I need a program away from the main source code.
/* added, else or to turn off if flame sense detects no flame*/
//modified start up for green light in set up
// will not run green light comes on at start
// both forms are valid -moved from return value-
// These constants won’t change:
const int analogPinss = A0; // pin that the switch is attached to
const int analogPinflm = A1; // pin that the flame sensor is attached to
const int ledPinnf = 13; // pin that the no flame sense LED is attached to
const int ledPinprg = 12; // pin that the purge LED is attached to
const int ledPinss = 11; // pin that the system start LED is attached to
const int ledPinstg2 = 10; // pin that the stage 2 LED is attached to
const int ledPinstg1 =9; // pin that the stage 1 LED is attached to
const int ledPinfp = 8; // pin that the fuel pump LED is attached to
const int ledPinsprk = 7 ; // pin that the spark output LED is attached to
const int threshold = 800; // an arbitrary threshold level that’s in the range of the analog inputs
int analogValue1 = 1; // variable to store the value coming from the on/off switch
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize all the LED pin as an output:
pinMode(ledPinss, OUTPUT);
pinMode(ledPinnf, OUTPUT);
pinMode(ledPinprg, OUTPUT);
pinMode(ledPinstg1, OUTPUT);
pinMode(ledPinstg2, OUTPUT);
pinMode(ledPinfp, OUTPUT);
pinMode(ledPinsprk, OUTPUT);
pinMode(analogPinss, INPUT);
pinMode(analogPinflm, INPUT);
digitalWrite(analogPinss, LOW); // turn on pull down resistor
digitalWrite(analogPinflm, LOW); //turn on pull down resistor
//initialize serial communications:
Serial.begin(9600);;
void exit (int exitcode);
// read the value of the Flame sensor:
int analogValue1 = analogRead(analogPinss); //on oss switch, taken out
int analogValue2 = analogRead(analogPinflm); // if the analog value 2 is low, LED off:
{ if (analogValue2 > threshold)
{digitalWrite(ledPinnf, LOW); //turn off no flame LED: note this is backwards
digitalWrite(ledPinprg, LOW);
} else if (analogValue2 < threshold)
{digitalWrite(ledPinnf, HIGH); //turn no flame LED on Note this is backwards
digitalWrite(ledPinprg, HIGH);
delay (8000); //purge on time 8 seconds
digitalWrite(ledPinprg, LOW); //turn purge timer off
//need to break program so that code below runs and skips upper code
//start new program, searching for flame
{ if (analogValue2 < threshold)
{digitalWrite(ledPinfp, HIGH);
digitalWrite(ledPinsprk, HIGH);
digitalWrite(ledPinstg1, HIGH);
delay (5000);
abort();} //forces abnormal termination
digitalWrite(ledPinstg2, HIGH);}
// print the analog value:
Serial.println(analogValue2);
A function prototype in a function is pretty much useless. Get rid of it.
Is this before, or after, the "if no flame for 8 seconds" part that tries to relight it? Conflicting requirements make for difficult programming.
Wrong. These statements do NOT do that.
I gave up reading your code. Use Tools + Auto Format before posting any code. Post code ONLY after clicking the # icon above the smiley faces.
Nothing follows the { on any line. Nothing follows any } ever.
:slight_smile:
THis is my problem., I have a conflicting requirement.
I must do the following:
1 CHeck that no flame sensor is good—IE sensor must read no flame
2 then I can start my program and wait for flame sensor to detect flame (IE no flame) and allow to run if I have flame detection
3. If no flame detection shiut off
4 If and after program starts I look at the flame sensor and if detects no flame I shut off permenantly
This is conflicitng stuff. I did not know if the go to function would help here? I am new to C++
digitalWrite(analogPinss, LOW); // turn off pull down resistor
digitalWrite(analogPinflm, LOW); //turn off pull down resistor
int analogValue1 = analogRead(analogPinss); //on oss switch, system start
digitalWrite(ledPinnf, HIGH); //turn on no flame LED: note this is backwards
else {
digitalWrite(ledPinnf, LOW); //turn no flame LED on Note this is backwards
//need to break program so that code below runs and skips upper code Big problem area
while(analogValue2 < threshold)
delay (5000);
while(1) {
http://:)\
kpar: :) THis is my problem., I have a conflicting requirement. I must do the following: 1 CHeck that no flame sensor is good---IE sensor must read no flame 2 then I can start my program and wait for flame sensor to detect flame (IE no flame) and allow to run if I have flame detection 3. If no flame detection shiut off 4 If and after program starts I look at the flame sensor and if detects no flame I shut off permenantly This is conflicitng stuff. I did not know if the go to function would help here? I am new to C++
1 Look up 'state machine'. 2 Post code using the hash button above the input box.
Thanks Henry, I a rewriting the code using the states to break up the conflicts. I am old school and used to the old basic box system with go to's.
kpar: Thanks Henry, I a rewriting the code using the states to break up the conflicts. I am old school and used to the old basic box system with go to's.
I too started with BASIC but soon got into Assembly language. Until the idea of the State Machine was pointed out to me, I too would have tried (and failed) your original method. Good luck with the rewrite. Let us know how you got on.
