Problem with hmc5843
I ve made my own shield for arduino. Part of that shield is a few sensors connected through pca9306 logic level translator. sensors are BMP085 ADXL345 HMC5843 and ITG3200, powered from arduinos 3.3v.
i use 510 ohms pull-ups on both sides of pca9306(took the average value of the datasheet).
The problem is: all sensors working fine except hmc5843(with 3 ceramic caps 4.7uf, 0.22 uf and 0.1uf). i ve tried next code
// Demonstration sketch for HMC5843 3-axis magnetometer (SparkFun SEN-09371)
// Mike Grusin, SparkFun Electronics, 8/20/2010
// i2c bus connections:
// connect SDA to analog 4
// connect SCL to analog 5
// power sensor with 3.3V from Arduino
// connect 5K-10K pullup resistors to SCA and SDL to 3.3V
#include <Wire.h>
  Wire.begin();        // set up i2c bus
  Serial.begin(9600);  // set up serial port
  delay(10);           // wait for HMC to boot up
  setup_HMC5843();     // initialize HMC
  read_HMC5843();      // get all magnetometer results, loop
void setup_HMC5843()
  byte result;
  Serial.print("setting up HMC\n");
  Wire.beginTransmission(0x1E);      // i2c address (use 7-bit address, wire library will modify for read/write)
  Wire.send(0x02);                   // register to write (0x02 = mode register, see datasheet)
  Wire.send(0x00);                   // write value to register (0.5Hz output rate, normal measurement configuration. See datasheet)
  result = Wire.endTransmission();
  printstatus(result);
void read_HMC5843()
  int x,y,z;
  byte xmsb,xlsb,ymsb,ylsb,zmsb,zlsb;
  byte result;
  Serial.print("ask for readings\n");
  Wire.send(0x03);                   // register to read (0x03 = first result register, see datasheet)
  Wire.requestFrom(0x1E, 6);         // read next six registers (0x03 to 0x08, see datasheet)
  x = Wire.available();              // make sure read was successful
  Serial.print(x, DEC); Serial.print(" bytes available\n");
  if (x == 6)
    xmsb = Wire.receive();    // read out six bytes = three readings (x,y,z)
    xlsb = Wire.receive();    // each reading is split into two bytes (msb, lsb)
    ymsb = Wire.receive();    // msb = most-significant byte ("high byte")
    ylsb = Wire.receive();    // lsb = least-significant byte ("low byte")
    zmsb = Wire.receive();
    zlsb = Wire.receive();
    x = word(xmsb,xlsb);      // combine bytes to get readings
    y = word(ymsb,ylsb);      // result = msb*256 + lsb
    z = word(zmsb,zlsb);
    Serial.print("X "); Serial.println(x, DEC);
    Serial.print("Y "); Serial.println(y, DEC);
    Serial.print("Z "); Serial.println(z, DEC);
void printstatus(byte result)    // Wire.endTransmission can tell you if an i2c transaction was successful or not
  Serial.print("I2C status: ");
  Serial.print(result, DEC);
  switch (result)
    case 0:
      Serial.print(", success!\n");
    case 1:
      Serial.print(", data too long to fit in transmit buffer\n");
    case 2:
      Serial.print(", received NACK on transmit of address\n");
    case 3:
      Serial.print(", received NACK on transmit of data\n");
    case 4:
      Serial.print(", other error\n");
the output i have is
setting up HMC
I2C status: 2, received NACK on transmit of address
ask for readings
0 bytes available
ask for readings
0 bytes available
ask for readings
0 bytes available
ask for readings
0 bytes available
i thought i could overheat or damage the sensor, so i ordered same from sparkfun and soldered it on 220 degrees, but problem are still here.
i have only 1 idea- problem is in the wrong pullups values, but atmel datasheet and pca9306 gives me absolutely different values, so i dont know which datasheet i must beleive.
also i disabled internall pullups in wire library.
Could someone help me please?
Can you post a schematic? Maybe the IC is wired incorrectly.
Also i've tried to add 100uf electrolytic capacitor in parallel of 4,7uf, but it didnt help.
That looks OK to me. If the other sensors are working OK with the logic level translator it unlikely that it's the pullup values. Maybe the sensor is bad or it's not attached to the board correctly?
Thanks. I already checked all routes and connections and I did not find any troubles. I will check it few more times. Maybe i missed something.
Is it possible that all 2 sensors I bought was instantly broken?
Any way thanks alot for Your answers.
You mentioned you soldered the HMC5843 to your boards, are you sure you made all the connections? That is a very tiny package.
