Hi!
I am trying to get some values from a MPU9250. I am using Bolderflights Library but I get the error "I2C connection unsuccessful". So I did some I2C scanning and with one of the scanners it says that I have a MPU6500, but on the chip it is labeled MPU-9250 / 6500. Can that be a problem? I get in the scanner that I have a connection on 0x68 with I read from. Thanks beforehand!
- UPDATE *
This code finds the I2C channel and prints: found i2c device on 0x68 and is mpu6500 and ready to use:
#include "MPU9250.h"
uint8_t addrs[7] = {0};
uint8_t device_count = 0;
template <typename WireType = TwoWire>
void scan_mpu(WireType& wire = Wire) {
Serial.println("Searching for i2c devices...");
device_count = 0;
for (uint8_t i = 0x68; i < 0x70; ++i) {
wire.beginTransmission(i);
if (wire.endTransmission() == 0) {
addrs[device_count++] = i;
delay(10);
Serial.print("Found ");
Serial.print(device_count, DEC);
Serial.println(" I2C devices");
Serial.print("I2C addresses are: ");
for (uint8_t i = 0; i < device_count; ++i) {
Serial.print("0x");
Serial.print(addrs[i], HEX);
Serial.print(" ");
uint8_t readByte(uint8_t address, uint8_t subAddress, WireType& wire = Wire) {
uint8_t data = 0;
wire.beginTransmission(address);
wire.write(subAddress);
wire.endTransmission(false);
wire.requestFrom(address, (size_t)1);
if (wire.available()) data = wire.read();
return data;
Serial.flush();
Wire.begin();
delay(2000);
scan_mpu();
if (device_count == 0) {
Serial.println("No device found on I2C bus. Please check your hardware connection");
while (1)
// check WHO_AM_I address of MPU
Serial.print("I2C address 0x");
byte ca = readByte(addrs[i], WHO_AM_I_MPU9250);
if (ca == MPU9250_WHOAMI_DEFAULT_VALUE) {
Serial.println(" is MPU9250 and ready to use");
} else if (ca == MPU9255_WHOAMI_DEFAULT_VALUE) {
Serial.println(" is MPU9255 and ready to use");
} else if (ca == MPU6500_WHOAMI_DEFAULT_VALUE) {
Serial.println(" is MPU6500 and ready to use");
Serial.println(" is not MPU series");
Serial.print("WHO_AM_I is ");
Serial.println(ca, HEX);
Serial.println("Please use correct device");
But when I read it this way it doesnt work:
Mpu9250 imu;
if (!imu.setup(0x68)) {
Serial.println("IMU initialization unsuccessful");
while (1) {}
Best regards Max
