I am having difficulties with using an iComSat GSM Module with Arduino Uno R3. I'm trying to build a project with a tilt switch and a 5v Single Channel Relay. The project aims to detect inactivity with the tilt sensor starting from when it is initially tilted and after a set period of time passes, the Relay would turn on and the GSM Module would send an sms to the user. I've tested with the tilt switch and the Relay without the GSM Module and it works great. The Relay turned on when it is tilted for a certain amount of time. I've also tested the GSM Module separately and got the sms. The problem starts when I try to combine both of it together. From the serial monitor it says that I'm not giving enough power to the GSM Module but when I disconnect the relay and tilt switch it works ok which led me to believe that it is a connection problem but I'm stuck and don't know why this is happening. If anyone could help me figure this one out it would be awesome. Here's a pic of everything connected together
. Below are the codes that I use:#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
boolean started=false;
// Defining a pin for the tilt sensor
#define SENSOR_PIN 5
// Defining a pin for the LED diode
#define LED_PIN 13
// Defining a pin for the piezo
//#define PIEZO_PIN 6
// Defining sensitivity time [ms]
#define SENSOR_TIME 10000
// Defining alarm duration time [ms] (5000 ms = 5 s)
#define ALARM_TIME 100
#define RELAY 7
// variable storing sensor's switching time
unsigned long sensor_time;
// variable storing alarm duration
unsigned long alarm_time;
// variable storing pitch change time
unsigned long signal_time = 0;
// variable storing the pitch value
// 0 - no sound
// 1 - first tone
// > 1 - second tone
byte sound_tone = 0;
void send_sms()
//Serial connection.
Serial.println("GSM Shield testing.");
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
started=true;
else Serial.println("\nstatus=IDLE");
if(started){
if (sms.SendSMS("+60102333893", "The iron has been switched off."))
Serial.println("\nSMS sent OK");
// Function invoked when the alarm is off
void alarm_on()
alarm_time = millis(); // storing the time when the tone was turned on
digitalWrite(LED_PIN, HIGH); // LED on
//sound_tone = 1; // Turning alarm siren on
send_sms();
void alarm_off()
if (millis() - alarm_time > ALARM_TIME) // checking alarm duration
digitalWrite(LED_PIN, LOW); // LED off
//sound_tone = 0; // Turning alarm siren off
//digitalWrite(RELAY, LOW);
// function checking sensor's state
void check_sensor()
// checking sensor's state
if (digitalRead(SENSOR_PIN) == HIGH)
// Action if off
if (sensor_time == 0) // checking if the state was changed
sensor_time = millis(); // storing sensor's activation time
// Condition, if sensor's state lasts for a specified time
else if (millis() - sensor_time > SENSOR_TIME)
alarm_on();
// Action if off
sensor_time = 0;
alarm_off();
// Setting the sensor's pin as input
pinMode(SENSOR_PIN, INPUT);
// Turning internal Pull Up resistor on
digitalWrite(SENSOR_PIN, HIGH);
pinMode(LED_PIN, OUTPUT);
//pinMode(RELAY, OUTPUT);
//digitalWrite(RELAY, HIGH);
check_sensor();
//alarm_signal();
