Problem with #include queue.h
Problems with ESP8266WiFi.h. When I include this library in a complicated sketch, I constantly get the message when compiling : fatal error queue.h no such file or directory.
I use Arduino 1.6.13, recently downloaded and installed. I also de-installed, downloaded and installed today again WinAvr20100110.
queue.h is present in WinAvr201000110/avr32/sys-include/sys but Arduino cannot find it.
This error occurs also in the minimum sketch, as follows:
#include <ESP8266WiFi.h>
What can be wrong?
HARRY02
Because it doesn't look in any library folders except its own and any libraries that you downloaded.
You have to explicitly #include every library in the sketch at top level so the IDE knows
which libraries to copy into the temporary build directory. If ESP8266.h uses queue.h, #include
both of these in your sketch at the top.
Problem solved: Arduino-Queue-Master contained uppercase Queue.h, while ESP8266WiFiType.h included lowercase queue.h. Changing Queue.h to queue.h solved the problem.
But new problem ESP8266WiFiGeneric.h includes and , without .h. Arduino reports: no such file or directory. What can be wrong now?
HARRY02
