problem with #include <WString.h>
hi
i am trying to run this small program (shown below) but i keep getting an error when trying to compile it :
21: error: WString.h: No such file or directory In function 'void loop()':
Bad error line: -3
what am i missing and yes i am a newbie.
what do i need to add or change any help would appreciated
thanks
chilliman
#include <Ethernet.h>
Simple Ethernet Test
Arduino server outputs simple text to browser
The circuit:
  • Arduino Duemilanove
  • Arduino Ethernet shield
  • Basic FTDI breakout 5V
    *LED connected to GND and digital pin 4 via resistor
By Minde
http://www.sciencprog.com/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 177 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(80); //server port
byte sampledata=50; //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin = 4; // LED pin
char link[]="http://www.scienceprog.com/"; //link data
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 4 to output
pinMode(ledPin, OUTPUT);
//enable serial datada print
void loop(){
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30)
//store characters to string
readString.append(c);
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//lets check if LED should be lighted
if(readString.contains("L=1"))
//led has to be turned ON
digitalWrite(ledPin, HIGH); // set the LED on
LEDON = true;
}else{
//led has to be turned OFF
digitalWrite(ledPin, LOW); // set the LED OFF
LEDON = false;
// now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
//set background to yellow
client.print("");
//send first heading
client.println("
HTTP test routines
client.println("
client.println("
//output some sample data to browser
client.println("Sample data: ");
client.print(sampledata);//lets output some data
client.println("
");//some space between lines
client.println("
//drawing simple table
client.println("Simple table: ");
client.println("
client.println("");
client.println("
row 1, cell 1 row 1, cell 2
row 2, cell 1 row 2, cell 2
client.println("
client.println("
//printing some link
client.println("Link: ");
client.print("Visit Scienceprog!");
client.println("
client.println("
//controlling led via checkbox
client.println("
LED control
//address will look like http://192.168.1.110/?L=1 when submited
client.println("LED
client.println("
//printing LED status
client.print("LED status: ");
if (LEDON)
client.println("ON");
client.println("OFF");
client.println("
client.println("
client.println("");
//clearing string for next read
readString="";
//stopping client
client.stop();
Have you installed the string library, and if so, where?
See the tutorial here:
(you didn't say what OS you're using, or which Arduino version)
thanks for the link, i am run windows 7 and arduino 0018 i will read the tutorial.
cjilliman :slight_smile:
worked great
thanks
chilliman :slight_smile:
