Problem with Input for an electric furnace using the keypad!
Hello, I have this project which is basically an electric furnace with user controls via a keypad, buttons, and an arduino. I use 4 buttons to input the mode of the furnace, which consists of a "Start", "Stop", "Reflow", and "Heat Treatment" button, now what I intend to happen is that the keypad should only work during the heat treatment so I can use it to input a set temperature, as for the reflow it should already have a setpoint.
Now my problem is the codes for my heating loop does not work, I can't seem to set my temperature, I can input the value and the LCD will display it but it seems that my value only works for that specific loop, which is not ideal because I intend to use it as my reference temperature for the duration of the heating. :confused:
Here are my codes for the project:
#include <LiquidCrystal.h>
#include <Keypad.h>
long set_temp;
long soaking_time;
int time1 = millis()/1000;
int time2 = 0;
int time3 = 0;
int firstreading;
int startPin;
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
char customKey;
const byte ROWS = 4; //four rows
const byte COLS = 3; //four columns
//define the cymbols on the buttons of the keypads
char keys [ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#',}
byte rowPins[ROWS] = {35, 41, 39, 37}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {36, 34, 38}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
  pinMode(9, OUTPUT);
  startPin = 23;
  pinMode(startPin, INPUT_PULLUP);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.print("Set Temp:");
  lcd.setCursor(0,1);
  lcd.print("Set Time:");
  if (time1 == 0)
    firstreading = analogRead(A0);
    Serial.print("first reading: ");
    Serial.println(firstreading);
void(* resetFunc) (void) = 0;
 customKey = customKeypad.getKey();
 switch(customKey)
 case '0' ... '9': // This keeps collecting the first value until a operator is pressed "+-*/"
 lcd.setCursor(10,0);
 set_temp = set_temp * 10 + (customKey - '0');
 lcd.print(set_temp);
 case '#':
 if (set_temp > 1000)
   set_temp = firstreading;
   Serial.print("Set temp :   ");
   Serial.println("ERROR");
   lcd.print("ERROR");
  else if (set_temp < 100 )
    lcd.print("ERROR");
    Serial.println(set_temp);
    soaking_time = SecondNumber(); // get the collected the second number
    set_temp = 0, soaking_time = 0; // reset values back to zero for next use
  case '*':
    resetFunc();
long SecondNumber()
  while( 1 )
    if(customKey >= '0' && customKey <= '9')
      soaking_time = soaking_time * 10 + (customKey - '0');
      lcd.setCursor(10,1);
      lcd.print(soaking_time);
    if(customKey == '#')
    break;  //return second;
    if(customKey == '*')
    resetFunc();
  if (soaking_time > 120)
      soaking_time = 0;
      Serial.print("Soaking Time :   ");
      lcd.print("ERROR");
    else if (soaking_time < 5 )
      soaking_time = 0;
      lcd.print("ERROR");
    Serial.println(soaking_time);
 return soaking_time;
 if (digitalRead(startPin) == HIGH)
   heating();
void heating()
  int sensorValue = analogRead(A0);
   if  (sensorValue <= set_temp)
   time3++;
   Serial.print("time3: ");
   Serial.println(time3);
     if  (sensorValue < 2*time3 + firstreading)
     digitalWrite(9, HIGH);
     Serial.print("reqd_reading:  ");
     Serial.println(2*time3 + firstreading);
   else if (sensorValue > set_temp)
   time2++;
   Serial.print("time2: ");
   Serial.println(time2);
   if (sensorValue > 802)
      digitalWrite(13, LOW);
    else if(sensorValue < 798)
      digitalWrite(13, HIGH);
  Serial.print("sensorValue: ");
  Serial.println(sensorValue);
  delay(1000);        // delay in between reads for stability
Help would be appreciated, Cheers!
 case '#':
When someone presses '#' you display set_temp, gather soaking_time, and then set both to zero?!?
Yes, I put it in there for resetting the input back to zero for the next time it will be used without having to turn it off. The '#' is basically used as an erase key, but it seems that it does not reset my input the way I intended, since the values don't reset?
Shouldn't you store the values somewhere before you erase them? How is the heater going to know the set_temp
and soaking_time if you erase them as soon as you set them?
I'm actually having trouble with storing the values? What would you recommend? Sorry I'm pretty new to this.
iSEYA:
Just copy the values to variables that you are NOT going to immediately set to zero.
I need to be able to store my input values (set_temp) in the loop for use as the set-point? I need to use those values later in the program? Will I have to set them to a new variable before using them in the loop? How do I go about copying them? The setting to zero is only used as a reset function actually for next use.
iSEYA:
Yes, I put it in there for resetting the input back to zero for the next time it will be used without having to turn it off. The '#' is basically used as an ENTER key, but it seems that it does not reset my input the way I intended, since the values don't reset?
EDIT: Sorry I meant enter key.
I've also tried this new approach, the values have been set but it no longer loops only showing once?
#include <Keypad.h>
int set_temp;
int soaking_time;
int time2 = 0;
int time3 = 0;
int firstreading;
const byte ssrPin = 13;
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  pinMode(ssrPin, OUTPUT);
  digitalWrite(ssrPin, LOW);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  if (time1 == 0)
int GetNumber()
   int num = 0;
   char key = kpd.getKey();
   while(key != '#')
      switch (key)
         case '0': case '1': case '2': case '3': case '4':
         case '5': case '6': case '7': case '8': case '9':
            num = num * 10 + (key - '0');
            lcd.print(num);
         case '*':
            num = 0;
            resetFunc();
      key = kpd.getKey();
   return num;
int GetNumber2()
   int num2 = 0;
   char key1 = kpd.getKey();
   while(key1 != '#')
      switch (key1)
            num2 = num2 * 10 + (key1 - '0');
            lcd.print(num2);
         case '*':
            num2 = 0;
            resetFunc();
   return num2;
   set_temp = GetNumber();
   soaking_time = GetNumber2();
Serial.print("set_temp: ");
Serial.println (set_temp);
Serial.print("soaking time: ");
Serial.println (soaking_time);
Serial.print("sensor:  ");
if(sensorValue <= set_temp)
  time2++;
  if(sensorValue >= firstreading + 2 * time2)
    Serial.println(firstreading + 2 * time2);
  else if(sensorValue < firstreading + 2 * time2)
    digitalWrite(ssrPin, HIGH);
else if(sensorValue > set_temp)
  time3++;
  if (time3++ < soaking_time)
    if(sensorValue > set_temp + 2)
    else if(sensorValue < set_temp)
    Serial.print("current temp:  ");
   else if (time3++ >= soaking_time)
