Problem with installing library
hi i cant get arduino library added i get this error.(Failed to install library: 'LiquidCrystal I2C:1.1.2'.
Error: 13 INTERNAL: Library install failed: creating temp dir for extraction: mkdir /libraries: read-only file system)
any help would be great thanks
You started a topic in the Uncategorised category of the forum whose description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Your topic has been moved to the Libraries category
Please explain exactly how you are installing the library and which version of the IDE you are using
hi sorry about that, its arduino ide 2.2.1 i am going through library maager and click install and i get the error message.
I don't know the reason of this error but you can try installing it manually. Just search for the library on google. There will probably have a result of the library from github. Download the folder and unzip it where your libraries folder is.
