I’d like to convert an integer value to a byte array and vice versa.
I’ve got it working on a C/C++ compiler but on the Arduino the conversion from the byte array to the integer value doesn’t work correctly for values > 32767 (int max).
long bytesToInteger(byte b[4]) {
long val = 0;
val = b[0] << 24;
val |= b[1] << 16;
val |= b[2] << 8;
val |= b[3];
return val;
void integerToBytes(long val, byte b[4]) {
b[0] = (byte )((val >> 24) & 0xff);
b[1] = (byte )((val >> 16) & 0xff);
b[2] = (byte )((val >> 8) & 0xff);
b[3] = (byte )(val & 0xff);
// DOES WORK (convert an integer to a byte array)
byte b[4];
integerToBytes(1056964608, b);
for (int i=0; i<4; ++i) {
Serial.println((int )b[i]);
// DOESN'T WORK (convert the byte array back to an integer)
long d = bytesToInteger(b);
Serial.println(d);
The long data type that I’m using seems to be the same on the Arduino as in the C/C++ compiler.
Arduino:
4 bytes
-2147483648 to 2147483647
C/C++ compiler:
4 bytes
-2147483647 to 2147483647
Any ideas? Thanks!
