Problem with interrupts for Seesaw Rotary Encoder and Feather RP2040
I'm working on a project with the Adafruit ANO Rotary Navigation Encoder to I2C Stemma QT Adapter and the Adafruit Feather RP2040.
Below is a modification of the rotary encoder example code.
A seesaw GPIO interrupt is attached to SS_SWITCH_UP. I have wired the rotary encoder interrupt pin to pin 6 on the feather. Additionally, I have attached an interrupt to feather pin 6.
Neither pins' interrupts work unless SS_SWITCH_UP is being polled with ss.digitalRead(). Not even the pullups work without polling.
I am using interrupts specifically because I do not want to be polling the seesaw buttons while other functions are running. How can I get these interrupts to work as intended? Am I using them incorrectly?
 * This example shows how to read from a seesaw encoder module.
 * The available encoder API is:
 *      int32_t getEncoderPosition();
        int32_t getEncoderDelta();
        void enableEncoderInterrupt();
        void disableEncoderInterrupt();
#include "Adafruit_seesaw.h"
#define SS_SWITCH_SELECT 1
#define SS_SWITCH_UP     2
#define SS_SWITCH_LEFT   3
#define SS_SWITCH_DOWN   4
#define SS_SWITCH_RIGHT  5
#define INTERRUPT_PIN    6
#define SEESAW_ADDR      0x49
Adafruit_seesaw ss;
int32_t encoder_position;
  while (!Serial) delay(10);
  Serial.println("Looking for seesaw!");
  if (! ss.begin(SEESAW_ADDR)) {
    Serial.println("Couldn't find seesaw on default address");
    while(1) delay(10);
  Serial.println("seesaw started");
  uint32_t version = ((ss.getVersion() >> 16) & 0xFFFF);
  if (version  != 5740){
    Serial.print("Wrong firmware loaded? ");
    Serial.println(version);
    while(1) delay(10);
  Serial.println("Found Product 5740");
  ss.pinMode(SS_SWITCH_UP, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_DOWN, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_LEFT, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_RIGHT, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_SELECT, INPUT_PULLUP);
  // get starting position
  encoder_position = ss.getEncoderPosition();
  Serial.println("Turning on interrupts");
  // ss.enableEncoderInterrupt();
  ss.setGPIOInterrupts((uint32_t)1 << SS_SWITCH_UP, 1);
  // feather INTERRUPT_PIN is connected to seessaw INT pin
  pinMode(INTERRUPT_PIN, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), detectInterrupt, FALLING);
  // PROBLEM: interrupts do not work without this polling
  if (! ss.digitalRead(SS_SWITCH_UP)) {
    Serial.println("UP pressed!");
  int32_t new_position = ss.getEncoderPosition();
  // did we move around?
  if (encoder_position != new_position) {
    Serial.println(new_position);         // display new position
    encoder_position = new_position;      // and save for next round
  // don't overwhelm serial port
  delay(10);
void detectInterrupt() {
  Serial.println("---interrupt---");
