It's kinda long that's why I didn't post it all at once...just the IR parts are bothering me everything else works fine...this is it:
#include "Ultrasonic.h"
#include <IRremote.h>
//DHLWSH METAVLHTWN
Ultrasonic ultrasonic( 12, 13 );
int x,s1,s2,s3,s4,g1,g2,onoff,dist1,dist2,k,x5144,x4539; //x:distance,s1:speed,g1+g2:apenergopoiites,dist:epithimiti apostasi
const int motor1Pin1 = 9; // H-bridge leg 1 (pin 2, 1A)
const int motor1Pin2 = 10; // H-bridge leg 2 (pin 7, 2A)
const int motor2Pin1 = 5;
const int motor2Pin2 = 6;
const int enablePin = 8; // H-bridge enable pin
unsigned long t1,t2,t3,t4,tt,p1,p2,ir; //t1,t2:xronoi gia freno,p1,p2:xronoi allagis s1,ir:received button
int right_ldr = 1;//analog pin to which LDR is connected
int left_ldr = 2;
int right_value = 0; //variable to store LDR values
int left_value = 0;
int x4439;
int x5145;
int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
//TELOS DHLWSHS METAVLHTWN
Serial.begin( 9600 );
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
pinMode(motor2Pin1, OUTPUT);
pinMode(motor2Pin2, OUTPUT);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, HIGH);
s1=0;
g1=0;
g2=0;
irrecv.enableIRIn(); // Start the receiver
ir=0;
onoff=0;
dist1=41;
dist2=30;
x4539=0;
x5144=0;
{ // RECEIVED IR
if (irrecv.decode(&results)) {
ir=(results.value);
irrecv.resume(); // Receive the next value
// EPEKSERGASIA IR
if (ir==16720605) {
onoff=1;
s1=85;
s2=86;
delay(100);
ir=0;
if (ir==16753245) {
onoff=0;
s1=0;
delay(100);
ir=0;
if (ir==16761405) {
++dist1;
++dist2;
delay(100);
ir=0;
if (ir==16712445) {
--dist1;
--dist2;
delay(100);
ir=0;
if (ir==16748655) {
++s2;
++s2;
delay(100);
ir=0;
if (ir==16754775) {
--s2;
--s2;
if (s1>s2) {
--s1;
--s1;
delay(100);
ir=0;
//TELOS IR
//ULTRASONIC
x=ultrasonic.Ranging(CM);
//TELOS ULTRASONIC
right_value = analogRead(right_ldr);
left_value = analogRead(left_ldr);
if (onoff==1){
if (right_value<220){
if (left_value<500){
s3=0;
s4=0;
else if (left_value>500) {
s3=0;
s4=200;
else if (right_value>220) {
s3=200;
s4=0;
// FRENO
if (x>40) {
k=0;
x5144=0;
x4439=0;
if (x<41) {
if (x<41&&x>30){
if (x5144==0){
t3=millis();
++x5144;
if (x<31&&x>20){
if (x4539==0) {
t4=millis();
++x4539;
if (x<20){
x5144=0;
x4539=0;
tt=(t4-t3);
if (tt<1000) {
if (k==0) {
analogWrite(motor1Pin1, 0);
analogWrite(motor1Pin2, 0);
analogWrite(motor2Pin1, s3);
analogWrite(motor2Pin2, s4);
delay(200);
analogWrite(motor1Pin2, 80);
++k;
onoff=0;
} // TELOS FRENOU
// AYKSOMEIWSH APOSTASHS
if (x>dist1) {
if (s1<s2) {
if (g1==0){
t1=millis();
++g1;
p1=(millis()-t1);
if (p1>200) {
++s1;
g1=0;
analogWrite(motor1Pin1, s1);
else if (x<dist1&&x>dist2){
else if (x<dist2){
if (s1>30){
if (g2==0){
t2=millis();
++g2;
p2=(millis()-t2);
if (p2>200) {
--s1;
g2=0;
// TELOS AYKSOMEIWSIS
// APENERGOPOIHSH
if (onoff==0){
s1=0;
