problem with: IRrecv irrecv(RECV_PIN);
I can not speak English well. I’m sorry for my mistakes! :confused:
I used arduino UNO and Windows10 and latest version of the Arduino software.
i connected 3 led to pin 2,4,6 and install IR receiver sensor to pin 11 and a buzzer to pin 3.
i need to on and off LED with remote control and play song with buzzer.
My code is:
#include <IRremote.h>
int RECV_PIN = 11; //
int output1 = 2;
int output2 = 4;
int output3 = 6;
int output4 = 10;
int buzzer = 3;
int itsONled[] = {0,0,0,0}
#define code1  47175 //
#define code2  14535 //
#define code3  25245 //
#define code4  43095 //
decode_results results;
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  Serial.begin(9600);   //
  irrecv.enableIRIn();  //
  pinMode(output1, OUTPUT);
  pinMode(output2, OUTPUT);
  pinMode(output3, OUTPUT);
  pinMode(output4, OUTPUT);
  if (irrecv.decode(&results)) {
    unsigned int value = results.value;
    switch(value) {
       case code1:
         if(itsONled[1] == 1) {        //
            digitalWrite(output1, LOW);   //
            itsONled[1] = 0;           //
         } else {                      //
             digitalWrite(output1, HIGH); //
             itsONled[1] = 1;          //
       case code2:
         if(itsONled[2] == 1) {
            digitalWrite(output2, LOW);
            itsONled[2] = 0;
             digitalWrite(output2, HIGH);
             itsONled[2] = 1;
       case code3:
         if(itsONled[3] == 1) {
            digitalWrite(output3, LOW);
            itsONled[3] = 0;
             digitalWrite(output3, HIGH);
             itsONled[3] = 1;
        case code4:
            beep(20,50);
    Serial.println(value); // you can comment this line
    irrecv.resume(); // Receive the next value
void beep(int fercancy , int delayms) {
  analogWrite(buzzer, fercancy);
  delay(delayms);
  analogWrite(buzzer,0);
  delay(delayms);
and the error is:
IR:13: error: expected ',' or ';' before 'IRrecv'
C:\Users\mohammad\Desktop\IR\IR.ino: In function 'void setup()':
IR:26: error: 'irrecv' was not declared in this scope
C:\Users\mohammad\Desktop\IR\IR.ino: In function 'void loop()':
IR:34: error: 'irrecv' was not declared in this scope
exit status 1
There may be other issues, but your first problem is that you are missing a semicolon:
should be
int itsONled[] = {0,0,0,0};
Thank you very much Solved Good luck :sunglasses:
i very try to listen to song of buzzer
help me please!
new code:
int output1 = 2;
int output2 = 4;
int output3 = 6;
int buzzer = 10;
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  beep(20,50);
  pinMode(buzzer, OUTPUT);
    switch(value) {
       case code1:
            itsONled[1] = 0;
             itsONled[1] = 1;
       case code2:
            itsONled[2] = 0;
             itsONled[2] = 1;
       case code3:
            itsONled[3] = 0;
             itsONled[3] = 1;
        case code4:
            beep(20,50);
    irrecv.resume();
  delay(delayms);
  delay(delayms);
