Problem with J Blum
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: “Arduino Uno”
C:\Users\Graham\Documents\Arduino\Jeremy BlumTutorials\Fresh start Jan 2021\Chap 4 Using Transistors driviving motors\Chap_4.14_Servo_Sweeping_Distance_Sensor\Chap_4.14_Servo_Sweeping_Distance_Sensor.ino: In function ‘int readDistance(int)’:
Chap_4.14_Servo_Sweeping_Distance_Sensor:60:3: error: expected primary-expression before ‘return’
return dist; // Return scaled distance
C:\Users\Graham\Documents\Arduino\Jeremy BlumTutorials\Fresh start Jan 2021\Chap 4 Using Transistors driviving motors\Chap_4.14_Servo_Sweeping_Distance_Sensor\Chap_4.14_Servo_Sweeping_Distance_Sensor.ino: At global scope:
Chap_4.14_Servo_Sweeping_Distance_Sensor:63:1: error: expected declaration before ‘}’ token
Multiple libraries were found for “Servo.h”
Used: C:\Users\Graham\Documents\Arduino\libraries\Servo
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries\Servo
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
Post YOUR code that caused those errors using code tags.
i do not have time to try to track down that tutorial.
Thanks for your reply Shannon. I haven’t yet got the hang of posting on the forum. The problem has been overcome. I used Jeremy Blum’s original code. Still cannot see where my mistake is. Project works. IR distance sensor works although the servo is very sticky. Gets stuck. Looking a ways to overcome this as the servo is working fine with simpler code projects. Thanks again.
Ostieman
