I've been working on coding a custom controller using keyboard emulation and have hit a bit of a brick wall. I'm not overly familiar with programming with C but according to all my reference material this should work. However once I load it onto the board it goes nuts. Could someone point out where I've gone wrong because I just don't see it.
int button1 = 2;
int button2 = 3;
int button3 = 4;
int button4 = 5;
int button5 = 6;
int button6 = 7;
int button7 = 8;
int button8 = 9;
int button9 = 10;
int button10 = 11;
int button11 = 12;
int button12 = 13;
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
pinMode(button5, INPUT_PULLUP);
pinMode(button6, INPUT_PULLUP);
pinMode(button7, INPUT_PULLUP);
pinMode(button8, INPUT_PULLUP);
pinMode(button9, INPUT_PULLUP);
pinMode(button10, INPUT_PULLUP);
pinMode(button11, INPUT_PULLUP);
pinMode(button12, INPUT_PULLUP);
Keyboard.begin();
//Power Management
if (!digitalRead(button1))
Keyboard.press(KEY_UP_ARROW);
Keyboard.release(KEY_UP_ARROW);
if (!digitalRead(button2))
Keyboard.press(KEY_DOWN_ARROW);
Keyboard.release(KEY_DOWN_ARROW);
if (!digitalRead(button3))
Keyboard.press(KEY_LEFT_ARROW);
Keyboard.release(KEY_LEFT_ARROW);
if (!digitalRead(button4))
Keyboard.press(KEY_RIGHT_ARROW);
Keyboard.release(KEY_RIGHT_ARROW);
//Engine boost
if (!digitalRead(button5))
Keyboard.press(KEY_TAB);
Keyboard.release(KEY_TAB);
//Cargo scoop
if (!digitalRead(button6))
Keyboard.press(KEY_HOME);
Keyboard.release(KEY_HOME);
//Ship lights
if (!digitalRead(button7));
Keyboard.press('l');
Keyboard.release('l');
//Landing gear
if (!digitalRead(button8))
Keyboard.press(KEY_INSERT);
Keyboard.release(KEY_INSERT);
//Frameshift
if (!digitalRead(button9))
Keyboard.press('j');
Keyboard.release('j');
//Silent running
if (!digitalRead(button10))
Keyboard.press(KEY_DELETE);
Keyboard.release(KEY_DELETE);
//Target highest threat
if (!digitalRead(button11))
Keyboard.press('h');
Keyboard.release('h');
//Target ahead
if (!digitalRead(button12))
Keyboard.press('t');
Keyboard.release('t');
delay(150);
Sorry, I'll try to be more specific. The moment I load the code onto the board it will just begin activating all commands at once without any push button trigger.
Edit: Also, like I said, my programming knowledge isn't great so I expect I may have added superfluous lines of code.
is not that much more typing, yet it is VERY clear what result you expect from digitalRead(), and what you expect to have happen when that result is obtained.
The circuit for each pin is currently PIN>Jumper to breadboard>Push button/momentary switch>Ground. Depending on which button is pressed the result should be the associated emulated keyboard button press. For example the button on pin 2 should result in the letter J being pushed.
Ok, so I finished rewriting it and cleaned it up a little and now it works perfectly. However I still fail to see the difference between this version and the version I posted at the top of the thread. Can anyone tell me what I'm missing? Was it the repeated Keyboard.release strings?
int button1 = 2;
int button2 = 3;
int button3 = 4;
int button4 = 5;
int button5 = 6;
int button6 = 7;
int button7 = 8;
int button8 = 9;
int button9 = 10;
int button10 = 11;
int button11 = 12;
int button12 = 13;
Keyboard.begin();
//Frameshift
//Landing gear
//Cargo scoop
//Hardpoints
Keyboard.press('u');
//Power management
//Balance
//Engines
//Systems
//Weapons
//Engine boost
//Ship lights
//Disable flight assist
Keyboard.press('z');
//Highest threat
Keyboard.releaseAll();
delay(150);
This code calls Keyboard.ReleaseAll() which only releases pressed keys. The other code releases keys that may not be pressed. Who knows what grief that causes. Well, actually, you do.
